Just another clutch tube fix, $10 no-weld or disassembly required |
Boomingbeetle |
Apr 22 2018, 10:40 AM
Member Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
My clutch cable tube was completely broken free and moving around inside the tunnel so I decided to try an easy brace/fix. It worked pretty well. I used a $10 two-piece shaft collar clamp with a 1/2” ID at the rear firewall. I don’t have access to my welder for a few months so this is temporary but may end up permanent... I did loosen the clutch cable at the trans so you can see the inner cable sheath entering the tube.
Lo-Fi Version | Time is now: 10th May 2024 - 11:22 PM |
