Trip odometer knob and cable |
Geezer914 |
Apr 22 2018, 12:38 PM
Geezer914 Group: Members Posts: 1,386 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
1975 914. Does anyone know how to remove this knob or cable so I can insert it into the back of the speedometer? And no, there is no set screw. (IMG:style_emoticons/default/headbang.gif)
adolimpio |
Apr 22 2018, 02:36 PM
Art Group: Members Posts: 180 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
I don't think that's the original knob. Mine is knurled metal and has a set screw.
I suspect someone might have glued that on. |
rgalla9146 |
Apr 22 2018, 02:40 PM
I don't think that's the original knob. Mine is knurled metal and has a set screw. I suspect someone might have glued that on. (IMG:style_emoticons/default/agree.gif) Try levering it off with a screwdriver |
914werke |
Apr 22 2018, 03:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Nope thats OE, late application Early cars had the knurled metal knob
Just pressed on a D shaft the early ver did use a VERY small screw |
Geezer914 |
Apr 22 2018, 04:12 PM
Thanks for the replies, I'll try prying it off with a couple of small screw drivers.
porschetub |
Apr 22 2018, 05:30 PM
scallyk9 |
Apr 22 2018, 05:52 PM
Member Group: Members Posts: 318 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
I have both early and late. The black plastic late model knob just pulls off. You should not need to pry it.
914Sixer |
Apr 22 2018, 06:20 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Get you a V shaped tack puller. Only a couple of dollars. Lots of other uses on the vehicle. Great for removing body plugs
GaroldShaffer |
Apr 22 2018, 06:30 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I have both early and late. The black plastic late model knob just pulls off. You should not need to pry it. (IMG:style_emoticons/default/agree.gif) |
mwyatt |
Aug 6 2020, 07:57 PM
Member Group: Members Posts: 84 Joined: 5-April 03 From: San Diego, CA Member No.: 516 Region Association: Southern California |
Can someone post for me how the odometer trip reset cable is attached to the underside of the dash? I have the black plastic knob as pictured, but my car just has the cable dangling (attached to the gauge but not the dash). Thanks!
Lo-Fi Version | Time is now: 26th April 2024 - 02:32 PM |
