ECU Pinout 1975 1.8 L Jet, Throttle Body Connections |
motorvated |
Apr 22 2018, 03:03 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
The three white wires going to the connector on the bottom of the Throttle Body on my 1975 1.8 L Jet motor have broken. I need to know what pin on the ECU connector each goes to. So far continuity check reveals one wire going to Pin 1, and another going to Pin 16. Third wire going to Pin 17. So which position on the connector does each wire go to? Retaining wire and two outboard grooves are on the bottom, single central groove on the top. Anybody know?
Thanks. |
Lo-Fi Version | Time is now: 18th May 2024 - 08:53 AM |
