New oil lines, Under construction |
PanelBilly |
Apr 23 2018, 07:33 PM
914 Guru Group: Members Posts: 5,804 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I've finished the supply line and now its tucked away from Ben's heat exchangers. Ignore the brake line that rubs. It will be fine when I finish putting the retainer clips on it
Now for the return line. This one is a bit more work. Still needs a few bends to fit closer to the oil tubes and clear the HE. I'm going to use a flexable line to fit out thru the body and connect to the tank |
mepstein |
Apr 23 2018, 08:51 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I got a lot of flack for my T fitting. I'm supposed to have it safety wired. You might want to do it before you fill with oil.
PanelBilly |
Apr 23 2018, 09:00 PM
Good idea
PanelBilly |
May 13 2018, 07:46 PM
Time is running out and I need to get the car sorted out before the WCR. I compromised on a solid return line and modified the Patrick hard line to be shorter so it wouldn’t interfer with the heat exchanger. I ran the old braided line back to the tank.
I got the hole drilled in the engine tin on one side but the teeth on the hole saw wore out before I could finish the second side. The cashier at Harbour Freight said I could bring the set back if I wasn’t happy with the quality. Looks like I need to do that. |
PanelBilly |
May 13 2018, 07:48 PM
Lo-Fi Version | Time is now: 5th May 2024 - 03:53 PM |
