Voltage Low, Red Brake Light Flickering |
mzapisek |
Apr 26 2018, 10:13 AM
Member Group: Members Posts: 91 Joined: 10-June 04 From: Syracuse, NY Member No.: 2,188 Region Association: North East States |
All original 1.7. Recently noticed voltage reading low (10.5) and red light which indicates emergency brake engaged flickering. I replaced the E brake trigger switch not thinking the two issues were related which did not not solve the flickering. Also noticing a periodic hesitation when driving. Any thoughts on what might be causing these symptoms and if they are related? Thanks.
Bartlett 914 |
Apr 26 2018, 10:39 AM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
All original 1.7. Recently noticed voltage reading low (10.5) and red light which indicates emergency brake engaged flickering. I replaced the E brake trigger switch not thinking the two issues were related which did not not solve the flickering. Also noticing a periodic hesitation when driving. Any thoughts on what might be causing these symptoms and if they are related? Thanks. 10.5 volts is too low. Where are you measuring? Do it at the battery. Check with the motor off and then running. Must be higher when running 13.5 or so. Check all fuses |
Lo-Fi Version | Time is now: 19th May 2024 - 04:36 PM |
