QUOTE(porschetub @ Apr 27 2018, 01:12 AM)
DON"T take voltage from any where but the battery,you should have 12 + volts at rest and 13.4 to 14.4 under full charging load.
+1. My GEN light used to come on and the center console voltmeter showed low voltage, but I had 13.5V at the battery with the car running. Bad grounds/bad connectors are common with our cars (I eventually removed the center console after I cleaned up all the connections.)
I have a corollary problem: my GEN light is on bright-ish at idle but dims as RPMs increase. Good voltage at the battery but of course lower voltage at lower RPM. So the GEN light is in INVERSE indicator...!
Need to break out the wiring diagram and figure out what's going on there. Good battery voltage at the fuse and the input wire, need to ring the wiring to see if there's some kind of connection problem to the alternator.
