Where does the oil temp wire go in the cabin? |
Air_Cooled_Nut |
Jun 8 2005, 12:14 AM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Looking under my 2.0L engine I discovered I must have an oil temp sender. Looking at the wiring diagrams for the '74 model year the wiring looks correct for an oil temp gauge (wire colors & single wire connector in engine bay). After reading the book by Dr. B. Johnson, "The 914 & 914/6 PORSCHE", I've determined that my '73 (originally a 1.7L engine) was bought with the appearance option and the oil temp was also an option. Also, the wiring for the sender runs into the wiring harness in the engine bay. My question is, where does it re-appear in the cabin?
I have a combination oil temp/fuel level gauge that I can install but I don't know where the wire terminates in the cabin. Under the dash? In the floor where a center console would be had the car been a 2.0L? Help! |
McMark |
Jun 8 2005, 01:32 AM
It's the green/black wire that goes to the center console, right near the shifter.
xsboost90 |
Jun 8 2005, 05:47 AM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
yeah its the same wire as the gauge in your dash. You will have to unplug the dash wire to plug in the consule gauge. I wired both together, but im not sure if that is going to mess w/ the resistance, so for now my dash gauge is just plugged in.
Lo-Fi Version | Time is now: 20th May 2024 - 04:19 PM |
