FS 5 lug converted Rear Hubs with studs $265 Shipped, 3 pair as of 3/12/2019, with or with out cores |
bdstone914 |
Apr 28 2018, 09:29 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit : Three more pair available as of 3/12/2019
Please read Eric's post on 5 lug conversion options. Make sure these are right for you. http://www.914world.com/bbs2/index.php?sho...p;hl=conversion I am selling pairs of the late (71-76) rear hubs that were redrilled to 5 x 130mm lug pattern. They do not have the extra bosses used on the 1970-1971 hubs They were stripped and black oxide coated. A professional machine shop machined them. I hand installed new 10.9 grade 14m x 45m studs. The 45mm studs are for use with steel or alloy wheels. Second picture is of hubs with out studs. Longer lenght studs for use with spacers available by request. These hubs only work with 914 stub axles and CV's. Not recommended for high (300+) HP applications. $265 no cores required shipped in the U.S. $215 With a good core of hubs returned. $75 Core deposit required. $175 with no studs. I do not accept hubs that have damage to the surface where the stub axle seats. Commonly caused using a BFH and a big socket. Thanks for looking. Attached thumbnail(s) |
flmont |
Sep 30 2018, 07:54 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I know this is the reverse of what you do Bdstone914,..But could you take a 5 lug hub and make it a 4 lug hub so I could use my 4 bolt Fuchs with 911 axles,..?? Thanks
Lo-Fi Version | Time is now: 29th April 2024 - 07:06 AM |
