FS 5 lug converted Rear Hubs with studs $265 Shipped, 3 pair as of 3/12/2019, with or with out cores |
bdstone914 |
Apr 28 2018, 09:29 PM
bdstone914 Group: Members Posts: 4,514 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Edit : Three more pair available as of 3/12/2019
Please read Eric's post on 5 lug conversion options. Make sure these are right for you. http://www.914world.com/bbs2/index.php?sho...p;hl=conversion I am selling pairs of the late (71-76) rear hubs that were redrilled to 5 x 130mm lug pattern. They do not have the extra bosses used on the 1970-1971 hubs They were stripped and black oxide coated. A professional machine shop machined them. I hand installed new 10.9 grade 14m x 45m studs. The 45mm studs are for use with steel or alloy wheels. Second picture is of hubs with out studs. Longer lenght studs for use with spacers available by request. These hubs only work with 914 stub axles and CV's. Not recommended for high (300+) HP applications. $265 no cores required shipped in the U.S. $215 With a good core of hubs returned. $75 Core deposit required. $175 with no studs. I do not accept hubs that have damage to the surface where the stub axle seats. Commonly caused using a BFH and a big socket. Thanks for looking. Attached thumbnail(s) |
Freezin 914 |
Mar 13 2019, 06:27 AM
Senior Member Group: Members Posts: 846 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
Hello, interested in these, question is, can I buy the front conversion parts separately from PMB? Is there any thing else needed to finish the rear conversion? Other than these hubs? Thank you.
bdstone914 |
Mar 14 2019, 08:17 AM
Hello, interested in these, question is, can I buy the front conversion parts separately from PMB? Is there any thing else needed to finish the rear conversion? Other than these hubs? Thank you. You will need rotors for the rear. You can have 4 lug rotors drilled to 5 lug. Or get 914-6 rotors and turn down the diameter 4mm. Ask Eric if he will sell the front conversion parts. Bruce @freezing914 |
Lo-Fi Version | Time is now: 29th April 2024 - 02:20 AM |
