track car project, track car project |
ablesnead |
Apr 30 2018, 11:14 AM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
Here goes a short novel on what I am selling....I know that photos are essential , but they are delayed a little...I am a computer neanderthal ...., and This car will likely need be bumped a bunch , to find that particular buyer, so I have decided to start now. I am selling my long term track car project ( was building for the Targa De Newfoundland )...I am old and don't have time to finish.....A 1974 914 that started as a complete finished rotary engined conversion car...It ran and drove fine . here's what the 25000.00 I have spent so far has resulted in : Rust free car....you wont find anything other than surface rust, on some interior spaces , car from New Mexico and Nevada . A complete 220 hp streetport 13b rotary built by Adkins in California..51mm modified weber.in perfect running condition with very low hours , a rebuilt 901 that shifts as it should , engine and box combined weigh less than a stock four...the finished car will be 220 very reliable horsepower and weigh less than 1800 lbs.. what is accomplished so far...rear Tangerine style rear flairs welded on but not yet blended in...top with a fiberglass air scoop bonded on...7000.00 dollars worth of front suspension...elephant racing , monoball rsr , cutom travel struts , tarret bar / aluminum cross piece ,massive front rotors with aluminum hats , rebuilt and new powder coated big red cailpers ( now big neon greens )...the rear trailing arme reinforced with chromemoly tubes , elephant racing bushing....tangerine racing outboard trailing arm mounts , raised strut top mounts , and reinforced inboard trailing arm mount...rear trunk is cut out back to trans mount area, traing arms are mounted with new bearing , new vented rotors and neon green powder coated boxster calipers,,all brake lines are run using pmb stainless steel lines , fuel lines are Tangerine racing stainlees steel ones , return for fuel injection included in install , shifter is rennshift with wevo hollow knob ( 100.00 dollar shift knob ...300.00 dollar accelerator pedal with 27 parts )...what an idictation !..Bruce stone redone pedal cluster...1000.00 dollars worth of revolution gauges cutom made 916 style front an rear bumpers...made to allow more air to radiator, so bigger opening and the rearumper vented at with flatter profile that doesn't stick out as far...car has good wheels and tires 17 inch 911 wheels and good tire it has a 914 rubber flat tow bar , and pullds straight ant great...I am going to sell this whole thing for 10000.00..I know I will have to be patient...I will not part out, many other new or refurbished parts go with it ...two real carbon fiber race seats , 1000.00 dollar fluidyne heat exchanger , mounts ect .....
burton73 |
Jun 8 2018, 07:40 PM
burton73 Group: Members Posts: 3,510 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
What is up with the 220HP Eng. that you comment on. Do you have all the pieces for the car? Hood , Trunk, Eng. Lights. What king of shape ae they in.
Bob B (IMG:style_emoticons/default/confused24.gif) |
infraredcalvin |
Jun 16 2018, 10:30 AM
Distracted Member Group: Members Posts: 1,510 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
What is up with the 220HP Eng. that you comment on. Do you have all the pieces for the car? Hood , Trunk, Eng. Lights. What king of shape ae they in. Bob B (IMG:style_emoticons/default/confused24.gif) If you’re interested in the motor, I may be interested in the rest of the car... maybe we can work a deal? Pat |
burton73 |
Jun 16 2018, 10:54 AM
What is up with the 220HP Eng. that you comment on. Do you have all the pieces for the car? Hood , Trunk, Eng. Lights. What king of shape ae they in. Bob B (IMG:style_emoticons/default/confused24.gif) If you’re interested in the motor, I may be interested in the rest of the car... maybe we can work a deal? Pat Looking at it as a water-cooled project. If I did it I would want the full car. Questions on what is used for a parking break. I am too fat for this car. Lots of holes for weight savings. Good or bad? Bob B |
Lo-Fi Version | Time is now: 3rd May 2024 - 04:07 AM |
