Used Koni Shocks, Opinions from suspension guru's please |
Allan |
Jun 8 2005, 05:58 PM
Could you guys take a look at these and give me some feedback.
Aaron says they look scarey... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
eeyore |
Jun 8 2005, 06:02 PM
It looks as if those custom lower perches not only adjust height, but pre-load as well. Somewhat clever.
SLITS |
Jun 8 2005, 06:39 PM
If the Koni shocks are good, they are good. You would have to disassemble them and check the resistance to be sure......$75 eacn isn't to bad....I would prefer $50, but then I am Forengi.
Adjustable is nice....... Aaron is a scare-dy-kat.....we'll waste your money for you.....buy....buy....buy until you drop. |
Marlow |
Jun 8 2005, 07:47 PM
Member Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 |
"have been cleaned out and reassembled with motorcycle fork oil"
Are they still Koni's if the oil's been changed to something else? Did they use motorcycle oil to start with? |
Mueller |
Jun 8 2005, 08:10 PM
i'd save my money and buy brand new Koni Yellows.....
Thorshammer |
Jun 8 2005, 08:26 PM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
Suspension fluid is similar in it's working ability.
If someone contacted Koni and got a Viscosity this is posssible and will be more available than getting fluid from Koni. However the Viscosity must be known. A drip cup test can be performed and even though the fluid will be old and worn out (yes it does wear out) an idea of what V is used can be found. A drip cup/funnel has the suspension fluid poured into it after being heated to a given temp. Then a stop watch is used and the drops are counted over a period of time. Next the fluid is heated to a higher temp and the process repeated. This will establish a viscosity AND a Viscosity index. A VI of over 380 will be a decent fluid, Some (spectro) motorcycle fluids have a VI of 400. Which indicates temperature stability over a range. Some fluids do not list a drip cup method and are labeled using SAE 2.5 wt, 5 wt, 7.5 wt etc... I have found many pf these fluids when tested are plus or minus 2wt up AND down. Most oil manufacturers use a base stock and blend from there. Normally the lighter the fluid the less change in damping characteristics over a given temperature range. I have actually heard of an engineer that used WATER as a shock fluid (with a touch of Redline water wetter as a lubricant) on a GTP car, but it had to be changed every session. Some fluids are petroleum and some are a synthetic blend. Polymer enhanced suspension fluid is NOT recomended due to the fact that shock valving has a tendency to shear the tiny fingers off of the polymers when pushed through valves and valving. As for these shocks, Koni is a good shock. I would however find out the cost of a KONI rebuild and factor that into the price of what you are buying. Hope this helps. Erik Post script: I have intentionally not described every detail, If a fluids engineer would like to comment and describe the process and the temperatures please do so as I only intended to impart a general idea of suspension fluid. |
Allan |
Jun 8 2005, 08:27 PM
So where is the cheapest place to get new ones??? The last quote I got was for almost $700.00. (IMG:http://www.914world.com/bbs2/html/emoticons/blink.gif) |
gfulcher |
Jun 8 2005, 08:29 PM
Diagnosis: Automobilitus. Prognosis: Terminal Group: Members Posts: 122 Joined: 3-January 04 From: San Francisco, CA Member No.: 1,501 Region Association: Northern California |
I concur. Used shocks are just that. I have six Konis sitting in a box in various states of disrepair. It's really hard to tell, if not impossible, if the shocks are any good when there are coils around 'em. I recently swapped out my red Koni's for a new set of four Yellow's with adjustable spring perches and can honestly say, the Koni Sport's are sweet as sweet can be. A bit pricey, yes - but worth every penny. -greg |
Lo-Fi Version | Time is now: 21st May 2024 - 01:55 AM |
