High idle issues |
High idle issues |
ChrisReale |
Jul 11 2003, 05:24 PM
Ok, here's whats ailing me now. I swapped TPS's today hoping to get rid of a slight bucking that happens every now and then. Didnt help, but another problem has arisen. The car wants to idle very high, like at 3000 rpm. I can bliip the throttle and it lowers abit, but it almost seems like the throttl;e cable is sticking. I can manually push on the throttle butterfly and the idle will go back to normal. I drive off, applying the slightest prressure to the acc. pedal, and the idle is right back up to 3000. any idea's? Where could the throttle cable be binding up?
TheCabinetmaker |
Jul 11 2003, 07:01 PM
Make sure you didn't unplug any vacuum lines. There is one in that area that will cause high idle.
Lo-Fi Version | Time is now: 28th April 2024 - 08:09 PM |
