ChrisReale
Jul 11 2003, 05:24 PM
Ok, here's whats ailing me now. I swapped TPS's today hoping to get rid of a slight bucking that happens every now and then. Didnt help, but another problem has arisen. The car wants to idle very high, like at 3000 rpm. I can bliip the throttle and it lowers abit, but it almost seems like the throttl;e cable is sticking. I can manually push on the throttle butterfly and the idle will go back to normal. I drive off, applying the slightest prressure to the acc. pedal, and the idle is right back up to 3000. any idea's? Where could the throttle cable be binding up?
TheCabinetmaker
Jul 11 2003, 07:01 PM
Make sure you didn't unplug any vacuum lines. There is one in that area that will cause high idle.
