Removing driveshaft at transmission, Need some help |
914 RZ-1 |
May 7 2018, 05:15 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
TravisNeff |
May 7 2018, 05:19 PM
right here, that is the paper gasket, a flat bladed screwdriver will work to free the CV from the axle flange. The boot will pull straight off (it is bonded to the metal cover), you may need to pry a little bit.
Attached thumbnail(s) |
LowBridge |
May 7 2018, 05:26 PM
Member Group: Members Posts: 370 Joined: 10-August 15 From: Lunenburg, MA Member No.: 19,045 Region Association: North East States |
it has 2 roll pins holding it on the spline so doing what Travis says will pop it right off or sometimes with a few small taps of a hammer will free it up also.
bretth |
May 7 2018, 07:57 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
On mine I just lay a 2x4 against the side of the CV and tapped the wood with a hammer a little on each side. Popped loose this way with fairly light tapping.
Boomingbeetle |
May 7 2018, 09:40 PM
Member Group: Members Posts: 118 Joined: 1-November 16 From: Orange County Member No.: 20,556 Region Association: Southern California |
You don’t need to take the wheel off. If you fiddle with it a bit then I think you’ll see it start to separate, it doesn’t take much. Are you trying to get the sidecover off to look at the R&P? once you separate the shaft, there’s a long bolt deep in the middle of the axle stub that threads into the differential. I think it’s a 19mm Head. You’ll need to remove that to get the cover off and the axle stub out.
porschetub |
May 7 2018, 10:18 PM
Advanced Member Group: Members Posts: 4,699 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Deadblow hammer on the joint nearer the axle.if they aren't tight you need to know why,the function of the roll pins is important.
I tighten my CV bolts at 32ft/lbs with a torque wrench,no gasket used and never had grease puke (IMG:style_emoticons/default/barf.gif) . Go well (IMG:style_emoticons/default/beer.gif) . |
Larmo63 |
May 7 2018, 10:29 PM
The built up muck on these acts like a sort of glue. Don't be shy, but be careful. You'll see it pop apart. (IMG:style_emoticons/default/smash.gif)
Dr Evil |
May 8 2018, 11:22 AM
You can carefully wedge a blunt flathead screw driver in there, displacing the gasket, and pry. Just be carful not to put big ole gouges in the surfaces, but it is not like the sealing surface of a head or anything.
914 RZ-1 |
May 8 2018, 07:49 PM
I got it. I used a chisel and dead blow hammer. I tapped it first to loosen it then hit the chisel where the gasket is, then rotated it, then did it again, going around until it broke loose. Thanks for the help!
Dr Evil |
May 8 2018, 08:57 PM
I got it. I used a chisel and dead blow hammer. I tapped it first to loosen it then hit the chisel where the gasket is, then rotated it, then did it again, going around until it broke loose. Thanks for the help! Mozeltov! Ya didn’t goof it up (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 17th May 2024 - 08:36 PM |
