No Start, 1972 914 will not start |
Mike1981 |
May 13 2018, 08:13 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello teeners
Looking for some advice please I have a 72 V8 conversion (I Know not a real 14) Really fun to drive I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position. The 2 things I have notice 1 Battery was low (Now Charging) 2 No cranking no clicking nothing. 3 Fuel pump cuts out 4 flashers tied to the e-brake keep flashing could it be the e-brake sensor? Clutch sensor/switch? Starter? ignition switch? Checked all relays and fuses I can find All seem good. Thanks Mike |
Mike1981 |
May 15 2018, 02:54 PM
Hello
Charged Battery overnight. It was reading 13.11 volts Re-installed in car nothing no click no crank no sound. Crawled under to the starter 12VDC on main lug Shoved red lead of meter into yellow wire Ignition switch wire I believe Grounded black lead onto door hinge keep Turned the key...no power thru the ignition wire.... is there a relay between the ignition switch in the column and the starter? https://www.facebook.com/photo.php?fbid=222...ype=3&ifg=1 |
Lo-Fi Version | Time is now: 6th May 2024 - 10:02 PM |
