No Start, 1972 914 will not start |
Mike1981 |
May 13 2018, 08:13 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello teeners
Looking for some advice please I have a 72 V8 conversion (I Know not a real 14) Really fun to drive I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position. The 2 things I have notice 1 Battery was low (Now Charging) 2 No cranking no clicking nothing. 3 Fuel pump cuts out 4 flashers tied to the e-brake keep flashing could it be the e-brake sensor? Clutch sensor/switch? Starter? ignition switch? Checked all relays and fuses I can find All seem good. Thanks Mike |
Mike1981 |
May 15 2018, 05:55 PM
Good Advice
I will clean battery terminal as well as the ground strap Thanks Mike |
xperu |
May 16 2018, 03:51 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Good Advice I will clean battery terminal as well as the ground strap Thanks Mike Not just the battery ground, but he body ground straps, disconnect the body straps and clean the connection area. Example, the on at the exhaust heat shields area under the rear trunk. I learned this from the forum years ago. Mike |
Lo-Fi Version | Time is now: 6th May 2024 - 07:36 PM |
