No Start, 1972 914 will not start |
Mike1981 |
May 13 2018, 08:13 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello teeners
Looking for some advice please I have a 72 V8 conversion (I Know not a real 14) Really fun to drive I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position. The 2 things I have notice 1 Battery was low (Now Charging) 2 No cranking no clicking nothing. 3 Fuel pump cuts out 4 flashers tied to the e-brake keep flashing could it be the e-brake sensor? Clutch sensor/switch? Starter? ignition switch? Checked all relays and fuses I can find All seem good. Thanks Mike |
Mike1981 |
May 20 2018, 10:58 AM
Hello Everyone
I have been cleaning connectors and checking the realy board. I am getting 12 volts into pin 1 from the ignition switch> Pin 1 and outgoing Pin 6 ohm out with no resistance. However no voltage out of pin 6 Checked all 3 relays (all Working) Scrubbed every connector I could find Any ideas? http://www.914world.com/bbs2/index.php?act...t&id=424733 |
Lo-Fi Version | Time is now: 6th May 2024 - 04:56 AM |
