No Start, 1972 914 will not start |
Mike1981 |
May 13 2018, 08:13 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello teeners
Looking for some advice please I have a 72 V8 conversion (I Know not a real 14) Really fun to drive I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position. The 2 things I have notice 1 Battery was low (Now Charging) 2 No cranking no clicking nothing. 3 Fuel pump cuts out 4 flashers tied to the e-brake keep flashing could it be the e-brake sensor? Clutch sensor/switch? Starter? ignition switch? Checked all relays and fuses I can find All seem good. Thanks Mike |
Mike1981 |
May 19 2018, 07:50 AM
Hello
Well I bought a new battery> No crank no start Replacced the ignition switch No crank no start Cleaned battery terminals no luck Next I will begin cleaning all electrical connections with wire brushes. I removed seat to check realy and found this...should it cut the connecton off and jump the 2 wires together? (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1526737807.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i273.photobucket.com-17663-1526737808.2.jpg) |
worn |
May 20 2018, 02:52 PM
can't remember Group: Members Posts: 3,152 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I am sorry to tell you now that the seats slide off the rails: you don’t have to unbolt them. Did you disconnect the seat wire or did you find it that way?
Lo-Fi Version | Time is now: 6th May 2024 - 05:11 PM |
