No Start, 1972 914 will not start |
Mike1981 |
May 13 2018, 08:13 AM
Member Group: Members Posts: 212 Joined: 21-July 14 From: Detroit MI Member No.: 17,663 Region Association: Southern California |
Hello teeners
Looking for some advice please I have a 72 V8 conversion (I Know not a real 14) Really fun to drive I just tried to start it and I do get power to dash and radio but the fule pump cuts out and no crank when I turn the key to the full starting position. The 2 things I have notice 1 Battery was low (Now Charging) 2 No cranking no clicking nothing. 3 Fuel pump cuts out 4 flashers tied to the e-brake keep flashing could it be the e-brake sensor? Clutch sensor/switch? Starter? ignition switch? Checked all relays and fuses I can find All seem good. Thanks Mike |
Mark Henry |
May 22 2018, 08:51 PM
The connector main harness plug in to relay board, disconnect it, pop the back off the connector, look for the yellow wire and test it (turning key) at that point.
If it doesn't work next stop is ignition switch, then power to switch, fuse block, etc. |
Lo-Fi Version | Time is now: 6th May 2024 - 05:25 PM |
