How to Remove Speedo Drive Seal, Speedo Drive Seal Removal (Transmission) |
Highland |
May 17 2018, 04:32 PM
Senior Member Group: Members Posts: 512 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So before I try and damage something, what's the best way to extract this seal?
Also I assume that's a sealing washer on top and cannot be reused? |
Mikey914 |
May 18 2018, 10:10 AM
The rubber man Group: Members Posts: 12,649 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A pick will do it.
I have the seals if you need them. The seal yes replace. The aluminum washer you can reuse if it's not damaged. The "new" part with all the seals is $65 if you want one. It has an extra seal so it will not leak. https://shop.914rubber.com/searchquick-subm...keywords=speedo Attached thumbnail(s) |
UROpartsman |
May 18 2018, 02:55 PM
Member Group: Members Posts: 291 Joined: 22-October 15 From: Simi Valley, CA Member No.: 19,288 Region Association: None |
It might be too big or overkill for removing this particular seal, but a puller like this Old Forge 7019 (available on Amazon) is a handy tool for getting seals out of smaller bores.
Dr Evil |
May 21 2018, 01:12 PM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I use a cheap set of dental picks, $0.99-2 at harbor freight. Easy and cheap to replace. Oddly enough, the 914 transmission seal kits do not come with this seal, but do come with the O ring. The 911/912 kits come with both o ring and seal.
Dr Evil |
Hey, I just say you are in San Diego. Ill be in town this week into next. I can see if I can find a spare and bring it with me if you want.
Highland |
May 21 2018, 01:20 PM
Thanks for all the input guys.
I've already got a couple seals on order, but appreciate the offer Dr. Evil. |
Lo-Fi Version | Time is now: 2nd May 2024 - 02:57 PM |
