How to Remove Speedo Drive Seal, Speedo Drive Seal Removal (Transmission) |
Highland |
May 17 2018, 04:32 PM
Senior Member Group: Members Posts: 513 Joined: 8-August 11 From: San Diego, CA Member No.: 13,418 Region Association: Southern California |
So before I try and damage something, what's the best way to extract this seal?
Also I assume that's a sealing washer on top and cannot be reused? |
Mikey914 |
May 18 2018, 10:10 AM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
A pick will do it.
I have the seals if you need them. The seal yes replace. The aluminum washer you can reuse if it's not damaged. The "new" part with all the seals is $65 if you want one. It has an extra seal so it will not leak. https://shop.914rubber.com/searchquick-subm...keywords=speedo Attached thumbnail(s) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:26 PM |
