16x7 wheels, 35mm offset, fit narrow body? |
Freezin 914 |
May 17 2018, 07:49 PM
Senior Member Group: Members Posts: 862 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
I have had a set of 16x7 VTO wheels with a 35mm offset, I am thinking they wouldn’t work on my narrow body car? Is this correct? I believe I would need a 23.3 offset? I will try to look through older threads.. (IMG:style_emoticons/default/type.gif)
Attached thumbnail(s) |
JamesM |
May 19 2018, 02:15 PM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
This is the exact wheel I run and have convinced a couple other locals to run as well, ET35 is perfect for the narrow body cars to run the widest possible tire. I havent seen 205/50/16 be an issue and you may even be able to go 215 depending on your car and what tire you run. At ET40 the inside of the 215s rub the front strut. ET23 on a 7 inch wheel will rub the fenders on a narrow body. Having a 7" wide wheel with shorter tire sidewall is a huge handling upgrade over stock.
Freezin 914 |
May 22 2018, 06:05 AM
This is the exact wheel I run and have convinced a couple other locals to run as well, ET35 is perfect for the narrow body cars to run the widest possible tire. I havent seen 205/50/16 be an issue and you may even be able to go 215 depending on your car and what tire you run. At ET40 the inside of the 215s rub the front strut. ET23 on a 7 inch wheel will rub the fenders on a narrow body. Having a 7" wide wheel with shorter tire sidewall is a huge handling upgrade over stock. Excellent pictures, your car looks great! Thank you for the information! |
Lo-Fi Version | Time is now: 18th May 2024 - 11:29 AM |
