Delayed power when accelerating ? |
cal914 |
May 20 2018, 11:11 AM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
I have a 2.0 original 6 engine upgraded too a 2.2 with E cams ,I had the carbs rejetted because she was apparently running to lean ,now when accelerating the car splutters and there’s a vagueness when accelerating at speed allmost as though it’s being pulled back (if that makes sense )she’s also she pops a lot at speed ,any advice would be great
Thanks Brian |
iankarr |
May 20 2018, 11:26 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I’m not a carb expert by any means, but had my share of the same issues on my carbed 2056. Oversll, it sounds like the carbs are out of sync....which would explain a lot of what you’re describing. Jetting may also need to be fine tuned further since that pulling back sensation indicates a “flat spot” and popping is usually cause by a lean condition.
I’m sure if you post your jets, vents, linkage, last rebuild and how you synched the carbs, the brain trust here (especially Chris at Tangerine) can help! |
Lo-Fi Version | Time is now: 18th May 2024 - 06:01 PM |
