Help. Can't get the rear chrome trim on targa bar!, It is starting to P*** me off! |
buck toenges |
May 20 2018, 07:23 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
O.K.
I have 3 clips. I assume that the clip part that hooks onto the flange goes in the bottom of the inner rail of the chrome bar. Do you put the clips in the chrome trim and slide the chrome trim on the flange? Do you place the clips on the roof and push on the chrome trim? I have tried and can't get anywhere. If I try and slide the chrome trim with the clips in the chrome trim piece on the roof the clip breaks. If I put the clips on first and then pop the chrome trim piece on the clips pop off the flange. signed, frustrated like h*** Buck By the way, Thanks for all the help. |
altitude411 |
May 20 2018, 08:09 PM
I drove my 6 into a tree Group: Members Posts: 1,306 Joined: 21-September 14 From: montana Member No.: 17,932 Region Association: Rocky Mountains |
*edit
76-914 |
May 20 2018, 09:44 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,491 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Stick a 1/2" wide flat metal piece like a small wood chisel into one end or the other. Work with the end that appears to give more than the other. As you pull the piece will want to arch up or down as it is not straight-but bow shaped. Let it bow down as you pull. This seemed to help. It will scare Hell out of you when it gives and one of the clips will shoot off into a Black Hole somewhere. (IMG:style_emoticons/default/beerchug.gif)
EDIT: LOL, just re-read title. ON not OFF. Take Rob-O's advice. |
Rob-O |
May 20 2018, 11:25 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Clips go into the targa trim. Then place it into position and push it on. No sliding it along.
altitude411 |
May 21 2018, 06:34 PM
clips go like this. I'm not totally sure but I thought there were four clips for the targa trim? (IMG:style_emoticons/default/confused24.gif)
Rand |
May 21 2018, 06:36 PM
Just to throw a wrench in the works....
DITCH that crap. I know, the CCWs need it. But, man, that's the first bit of cheesey blingy crappy extraneous garbage added on after the car was built. Shave it. Unless you love special crevasse-like places that capture rust and eat your car for no reason except some goofy trim. Why? Why? (Yeah, I already called out the CCWs... WHY??) (IMG:style_emoticons/default/stirthepot.gif) |
windforfun |
May 21 2018, 06:51 PM
Senior Member Group: Members Posts: 1,776 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Is this the long horizontal piece or the short vertical ones?
bdstone914 |
May 21 2018, 08:55 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Just to throw a wrench in the works.... DITCH that crap. I know, the CCWs need it. But, man, that's the first bit of cheesey blingy crappy extraneous garbage added on after the car was built. Shave it. Unless you love special crevasse-like places that capture rust and eat your car for no reason except some goofy trim. Why? Why? (Yeah, I already called out the CCWs... WHY??) (IMG:style_emoticons/default/stirthepot.gif) Not a good idea at all. The targa roof seal seals on the trim part. Only you can answer is to why you make the posts you do. Your posts rarely make sense to me. |
Larmo63 |
May 22 2018, 06:51 AM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I did the targa vinyl recently and the rear trim was no issue at all. I thought there were five clips on my trim bar, but some say less.
It snapped right on in seconds. I might have used a little persuasion, but no problems. |
bdstone914 |
May 22 2018, 07:26 AM
I did the targa vinyl recently and the rear trim was no issue at all. I thought there were five clips on my trim bar, but some say less. It snapped right on in seconds. I might have used a little cousin, but no problems. Larmo, do you mean a little cussing or cousin (like child labor) ? Three is what Porsche used. More is OK. |
colingreene |
May 22 2018, 01:26 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Knowing him it could be either really.
Rand |
May 22 2018, 02:38 PM
Just to throw a wrench in the works.... DITCH that crap. I know, the CCWs need it. But, man, that's the first bit of cheesey blingy crappy extraneous garbage added on after the car was built. Shave it. Unless you love special crevasse-like places that capture rust and eat your car for no reason except some goofy trim. Why? Why? (Yeah, I already called out the CCWs... WHY??) (IMG:style_emoticons/default/stirthepot.gif) Not a good idea at all. The targa roof seal seals on the trim part. Only you can answer is to why you make the posts you do. Your posts rarely make sense to me. Fair enough. I added a "smiley" figuring it would not make sense to some. My roof sits on the latches on the inside, not the trim of the outside. The seal against the trim is nothing I've ever missed. Water doesn't come in that way. To each his own. I like the clean look sans-bling and there's no trim to trap moisture. Do what you want, this is just bouncing thoughts around. |
buck toenges |
May 22 2018, 06:17 PM
Well, I cut the vinyl off the flange, cleaned the glue off the flange, and it clipped on like it is suppose too. Easier once you got all the crap off the flange.
Thanks, Buck |
Lo-Fi Version | Time is now: 26th April 2024 - 11:57 PM |
