Help. Can't get the rear chrome trim on targa bar!, It is starting to P*** me off! |
buck toenges |
May 20 2018, 07:23 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
O.K.
I have 3 clips. I assume that the clip part that hooks onto the flange goes in the bottom of the inner rail of the chrome bar. Do you put the clips in the chrome trim and slide the chrome trim on the flange? Do you place the clips on the roof and push on the chrome trim? I have tried and can't get anywhere. If I try and slide the chrome trim with the clips in the chrome trim piece on the roof the clip breaks. If I put the clips on first and then pop the chrome trim piece on the clips pop off the flange. signed, frustrated like h*** Buck By the way, Thanks for all the help. |
Rand |
May 21 2018, 06:36 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Just to throw a wrench in the works....
DITCH that crap. I know, the CCWs need it. But, man, that's the first bit of cheesey blingy crappy extraneous garbage added on after the car was built. Shave it. Unless you love special crevasse-like places that capture rust and eat your car for no reason except some goofy trim. Why? Why? (Yeah, I already called out the CCWs... WHY??) (IMG:style_emoticons/default/stirthepot.gif) |
bdstone914 |
May 21 2018, 08:55 PM
bdstone914 Group: Members Posts: 4,522 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Just to throw a wrench in the works.... DITCH that crap. I know, the CCWs need it. But, man, that's the first bit of cheesey blingy crappy extraneous garbage added on after the car was built. Shave it. Unless you love special crevasse-like places that capture rust and eat your car for no reason except some goofy trim. Why? Why? (Yeah, I already called out the CCWs... WHY??) (IMG:style_emoticons/default/stirthepot.gif) Not a good idea at all. The targa roof seal seals on the trim part. Only you can answer is to why you make the posts you do. Your posts rarely make sense to me. |
Rand |
May 22 2018, 02:38 PM
Just to throw a wrench in the works.... DITCH that crap. I know, the CCWs need it. But, man, that's the first bit of cheesey blingy crappy extraneous garbage added on after the car was built. Shave it. Unless you love special crevasse-like places that capture rust and eat your car for no reason except some goofy trim. Why? Why? (Yeah, I already called out the CCWs... WHY??) (IMG:style_emoticons/default/stirthepot.gif) Not a good idea at all. The targa roof seal seals on the trim part. Only you can answer is to why you make the posts you do. Your posts rarely make sense to me. Fair enough. I added a "smiley" figuring it would not make sense to some. My roof sits on the latches on the inside, not the trim of the outside. The seal against the trim is nothing I've ever missed. Water doesn't come in that way. To each his own. I like the clean look sans-bling and there's no trim to trap moisture. Do what you want, this is just bouncing thoughts around. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:25 PM |
