scissor lift |
scissor lift |
porsche-tom |
May 22 2018, 05:55 AM
Member Group: Members Posts: 140 Joined: 7-March 13 From: jensen beach fl Member No.: 15,626 Region Association: None |
any recommendations on a good scissor lift for a 914? I have a small garage so a 4 post or a 2 post would be to large. Can you drop engine/trans or is there too much in the way?
JRust |
May 23 2018, 10:28 AM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I have a Bend pak Scissor lift & it is awesome. Yes you need to add some runners to get your 914 to clear driving over it. It is easily high enough to pull the motor. I use the harbor freight 1000lb hydraulic table/cart to remove mine. Doesn't get any easier. Raise my lift all the way put cart under. Remove all bolts holding it up & drop that sucker. All the years I spent jacking up the rear end & crawling around on the floor. What a flippin waste of time. This is one of the best possible tools you will ever buy if you work on your car. It has paid for itself many times over int he 7 years I've had it
Lo-Fi Version | Time is now: 7th May 2024 - 01:11 AM |
