Hydrolock!, In praise of cheap hi-torque starter.... |
wndsrfr |
May 22 2018, 08:36 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
OK, the /4 with ITB's & I added the Honda Goldwing air cleaners to quiet the intake rasp. Parked outside under fabric cover and old poly tarp. Custom lid with same coverage as stock, solid in front protecting ignition but open mesh in back. No rain tray as no room there at all under the lid.
Went to start it & "BANG"--not backfire type sound, solid mechanical "BANG" & no crank beyond that. Hmmm.....pulled the plugs & sure enough, #3 had water on it.....ugh. Went to spin it with the starter & only got starter motor whirr...no cranking. OK, up on the lift, pulled the starter & here's what I fished out of the flywheel housing.... Replacement starter installed, engine purrs like it should--whew! Sooo....in spite of my aversion to the cheap hi-torque starters that chew up the flywheel in favor of the OEM much stronger one, I dodged a cannonball on this one. Be careful out there all you GT clone guys--be sure you have good rain hats on your intakes!! |
sithot |
May 22 2018, 08:52 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
OK, the /4 with ITB's & I added the Honda Goldwing air cleaners to quiet the intake rasp. Parked outside under fabric cover and old poly tarp. Custom lid with same coverage as stock, solid in front protecting ignition but open mesh in back. No rain tray as no room there at all under the lid. Went to start it & "BANG"--not backfire type sound, solid mechanical "BANG" & no crank beyond that. Hmmm.....pulled the plugs & sure enough, #3 had water on it.....ugh. Went to spin it with the starter & only got starter motor whirr...no cranking. OK, up on the lift, pulled the starter & here's what I fished out of the flywheel housing.... Replacement starter installed, engine purrs like it should--whew! Sooo....in spite of my aversion to the cheap hi-torque starters that chew up the flywheel in favor of the OEM much stronger one, I dodged a cannonball on this one. Be careful out there all you GT clone guys--be sure you have good rain hats on your intakes!! Lucky after all of the rain we've had. Buy a lottery ticket! Hydrolock: |
Lo-Fi Version | Time is now: 8th May 2024 - 11:58 PM |
