914- 6 GT oil line eye candy |
mb911 |
May 24 2018, 01:25 PM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
tygaboy |
May 24 2018, 01:57 PM
914 Guru Group: Members Posts: 5,294 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
(IMG:style_emoticons/default/wub.gif) Pretty! (IMG:style_emoticons/default/wub.gif)
What's the ID and wall thickness of that tube? Any possibility I could run these as water lines...? |
mb911 |
May 24 2018, 02:55 PM
(IMG:style_emoticons/default/wub.gif) Pretty! (IMG:style_emoticons/default/wub.gif) What's the ID and wall thickness of that tube? Any possibility they could be used as water lines...? I forget the ID and will have to measure. From memory .875 ID.. |
Cairo94507 |
May 24 2018, 03:46 PM
Michael Group: Members Posts: 9,763 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That's the ticket. (IMG:style_emoticons/default/beerchug.gif)
McMark |
May 24 2018, 03:52 PM
(IMG:style_emoticons/default/wub.gif) Pretty! (IMG:style_emoticons/default/wub.gif) What's the ID and wall thickness of that tube? Any possibility I could run these as water lines...? Damn that's smart... (IMG:style_emoticons/default/idea.gif) |
tygaboy |
May 25 2018, 06:37 AM
(IMG:style_emoticons/default/wub.gif) Pretty! (IMG:style_emoticons/default/wub.gif) What's the ID and wall thickness of that tube? Any possibility they could be used as water lines...? I forget the ID and will have to measure. From memory .875 ID.. Ben - I don't want to hijack this thread so PM me, if you'd prefer. I've purchased 1.25 OD aluminum tube but think I could get by with 1" and all -16 fittings. That's what Tony is running and he's seeing no cooling issues. I wouldn't want to go smaller than that. But do let me know the ID? Thanks! |
GeorgeRud |
May 25 2018, 09:11 AM
Back before these were an option, I used -12 braided lines to feed my front cooler on my 2.7 conversion. It works fine on my street driven car, though I’d prefer going to -16 for a track car. I think Ben’s copy the factory design, so should work well.
mb911 |
May 25 2018, 11:19 AM
Back before these were an option, I used -12 braided lines to feed my front cooler on my 2.7 conversion. It works fine on my street driven car, though I’d prefer going to -16 for a track car. I think Ben’s copy the factory design, so should work well. Yes for oil cooled but he is running am ls v8 engine.. Oh and the fittings are 30mm.. I just need to double check id.. |
mb911 |
May 25 2018, 03:16 PM
They are 7/8" od. 3/4" id
Hope that helps. |
Jun 12 2018, 12:04 AM
Resident German Group: Admin Posts: 41,644 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
They are 7/8" od. 3/4" id Hope that helps. Bummer, i would gladly buy a set if they also came in 1" ID. 3/4" is too small for my 3.6L. (IMG:style_emoticons/default/sad.gif) |
Jun 12 2018, 12:11 AM
They are 7/8" od. 3/4" id Hope that helps. Bummer, i would gladly buy a set if they also came in 1" ID. 3/4" is too small for my 3.6L. (IMG:style_emoticons/default/sad.gif) I lied, my current lines are -12 so they are in fact 3/4" ID. Damn it, now you got me thinking ... (IMG:style_emoticons/default/unsure.gif) |
mb911 |
Jun 12 2018, 06:00 AM
They are 7/8" od. 3/4" id Hope that helps. Bummer, i would gladly buy a set if they also came in 1" ID. 3/4" is too small for my 3.6L. (IMG:style_emoticons/default/sad.gif) I lied, my current lines are -12 so they are in fact 3/4" ID. Damn it, now you got me thinking ... (IMG:style_emoticons/default/unsure.gif) Lol.. They are a big line.. Let me know if I can help.. |
914forme |
Jun 12 2018, 06:09 PM
Ben very Nice (IMG:style_emoticons/default/aktion035.gif)
I like how your thinking Chris (IMG:style_emoticons/default/idea.gif) |
mb911 |
Jun 12 2018, 08:36 PM
Still have 20 sets none plated let me know if anyone needs them.
Lo-Fi Version | Time is now: 18th May 2024 - 09:16 PM |
