Rear too low - V8 conversion |
DickSteinkamp |
May 25 2018, 09:03 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
I know..."If it's too low...I'm too old". But maybe not in this case.
1976 with a SBC conversion using Renegade and Kennedy parts. Stock rear springs. I'd like it to sit 1 1/2" higher in the rear (I don't want the front any lower). What's the solution? New stock rear springs? 914-6 rear springs? Some after market springs? Adjustable spring plates? (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-20876-1527303802.1.jpg) Thanks! |
Chris914n6 |
May 26 2018, 02:45 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Stock springs are 100lbs and no good for the weight of a V8. 180lb springs are common at most p-car stores. Renegade sells 200lb springs last time I checked that supposedly match better with the stiffer 911 front suspension swap.
Stock shocks will work just fine unless they are dead/leaking. Bilsteins are great for our cars plus have the advantage of some height adjustability. The KYB (white) are valved too stiff and I'd swap them out for a much better ride. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:27 PM |
