securing pedal board?, can't remember what goes where |
Calwaterbear |
May 26 2018, 10:24 AM
Member Group: Members Posts: 207 Joined: 15-November 14 From: United States Member No.: 18,123 Region Association: Central California |
so on my 72 1.7 the board that goes over the pedal set was completely shot, i scavenged one from a junkyard car, then used it as a template to make my own out of plywood - and preserved it with several coats of polyurathane.
so time to put it back in the car - and I'm having trouble remembering how I took it out originally. The 1/2 moon cutout on the left side - thats no problem it's held by the metal tab secured by the bolt going through it and into the threads on the floor. and the scooped cut out above the clutch cut out - I assume thats for clearance of the wiring harness - correct? can any one tell me about/ why the 2 oblong cuts on either side of the clutch cut out? and on the right side? I have a hole there the size of a nickle, but its over the opening in the tunnel - I don't see any place to secure it - is there some sort of mounting system I am unaware of? Thanks in advance CWB |
dr914@autoatlanta.com |
May 26 2018, 11:04 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
clutch stop plate bolts into the oblong holes, a round clamp goes on the right side with an allen and the allen screws into the black center tunnel access plate
so on my 72 1.7 the board that goes over the pedal set was completely shot, i scavenged one from a junkyard car, then used it as a template to make my own out of plywood - and preserved it with several coats of polyurathane. so time to put it back in the car - and I'm having trouble remembering how I took it out originally. The 1/2 moon cutout on the left side - thats no problem it's held by the metal tab secured by the bolt going through it and into the threads on the floor. and the scooped cut out above the clutch cut out - I assume thats for clearance of the wiring harness - correct? can any one tell me about/ why the 2 oblong cuts on either side of the clutch cut out? and on the right side? I have a hole there the size of a nickle, but its over the opening in the tunnel - I don't see any place to secure it - is there some sort of mounting system I am unaware of? Thanks in advance CWB |
Calwaterbear |
May 26 2018, 11:11 AM
clutch stop plate bolts into the oblong holes, a round clamp goes on the right side with an allen and the allen screws into the black center tunnel access plate ah crap George, so now I have to figure out if i actually have the clutch stop plate in my boxes of spare/ scavenged parts |
May 26 2018, 11:40 AM
clutch stop plate bolts into the oblong holes, a round clamp goes on the right side with an allen and the allen screws into the black center tunnel access plate ah crap George, so now I have to figure out if i actually have the clutch stop plate in my boxes of spare/ scavenged parts you will find it, silver rectangular metal bracket with two studs and a small rubber stop |
troth |
May 26 2018, 12:16 PM
Member Group: Members Posts: 151 Joined: 17-August 16 From: CT/WA Member No.: 20,305 Region Association: None |
9fourteen14 |
Jun 3 2018, 10:57 AM
PORSCHE LUVA Group: Members Posts: 135 Joined: 5-July 15 From: boston Member No.: 18,920 Region Association: North East States |
clutch stop plate bolts into the oblong holes, a round clamp goes on the right side with an allen and the allen screws into the black center tunnel access plate ah crap George, so now I have to figure out if i actually have the clutch stop plate in my boxes of spare/ scavenged parts you will find it, silver rectangular metal bracket with two studs and a small rubber stop i got my metal plate out but still cannot get the board out. i want to get to the junction of the brake light F 54 on schematic. my reverse lights are not working. i have 74 2.0. see pictures below |
TheCabinetmaker |
Jun 3 2018, 11:28 AM
Board is held in by the two screws with the dimpled washers, on the left and right.
9fourteen14 |
Jun 3 2018, 01:21 PM
Board is held in by the two screws with the dimpled washers, on the left and right. awesome thanx so much got it... and fixed the reverse lights... it was that join at F 54 the connection was not made. all i did was puch the 3 prong connector onto the switch. thanx so much 914 luva |
Lo-Fi Version | Time is now: 15th May 2024 - 12:55 PM |
