Porsche carpet Installation/gluing sequence., My buddy is installing carpeting and needs help |
dcheek |
May 27 2018, 11:12 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
I searched this forum and Google and I can't find the sequence for installing a carpet kit in a 914. Pelican has one for a 911 but not for a 914.
Anybody have a link, or can send a PDF of the installation instructions? Dave |
dr914@autoatlanta.com |
May 29 2018, 11:58 AM
914 Guru Group: Members Posts: 7,858 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
to do a great job with the ten piece carpet set, you will have to remove the seats, the em brake handle as it goes through the carpet, the back pad as the rocker carpet goes under it, the speaker grilles, the pedal board, and the steering column as the bulkhead carpet has the hole for the steering shaft to g through. Start by installing the rocker carpets with a light bit of 3m spray trim adhesive, then install the left and right bulkhead pieces with some light spray trim adhesive cutting the slits for the speaker screw receivers to poke through. Next glue the pedal board piece as high as you can behind the board banking it against the flat part of the cowl. The rest is easy, center tunnel carpet then install the speakers the steering column, the emergency brake. pedal board (board helps cinch up the small pedal board carpet and the backpad (great time with the back pad removed to check for a loose rear window) then install the seats, and finally the four floor pieces (nine if you have a 70-71)
Lo-Fi Version | Time is now: 16th May 2024 - 04:01 PM |
