A spot of rust, Rust treatment |
dsla |
May 28 2018, 12:18 PM
Newbie Group: Members Posts: 2 Joined: 7-October 17 From: UK Member No.: 21,491 Region Association: England |
Hi all
Spotted a tiny bit of rust when my 914 was up on the lift. So how worried should I be and what's the best way to treat this? Thanks Dan (IMG:http://www.914world.com/bbs2/uploads_offsite/preview.ibb.co-21491-1527531523.1.jpg) |
Mark Henry |
May 28 2018, 01:10 PM
Krud Kutter
mgphoto |
May 28 2018, 01:21 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Find the source, looks like wash down from the battery?
Several options, cover with navel jelly and paint. Sand, acid wash, rinse with water, degrease, epoxy primer, paint, or not. Same as above but POR-15 instead of epoxy primer. Kill the rust now, less to deal with later. |
Geezer914 |
May 28 2018, 02:18 PM
Geezer914 Group: Members Posts: 1,423 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Remove the small rubber plug so water can drain out.
majkos1 |
May 29 2018, 07:10 AM
Member Group: Members Posts: 215 Joined: 11-August 17 From: Mile High 914 Member No.: 21,338 Region Association: Rocky Mountains |
dr914@autoatlanta.com |
May 29 2018, 07:16 AM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
wire brush thoroughly after removing the fuel pump mounts, coat with POR-15 rust paint, and top coat with the original factory color. (Ravenna Green I assume?) I would also leave out the drain hole rubber plug, that plug is what caused many 914s to rust through in this area
dsla |
May 29 2018, 10:48 AM
Thanks all, much appreciated.
Dan |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:41 AM |
