Dyno Run |
Dyno Run |
sharper |
May 28 2018, 07:52 PM
Member Group: Members Posts: 146 Joined: 5-June 03 From: Woodstock, GA Member No.: 789 Region Association: South East States |
tazz9924 |
May 28 2018, 11:06 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
Nice, but its not 200hp (IMG:style_emoticons/default/biggrin.gif)
porschetub |
May 28 2018, 11:38 PM
looks close to me,you can sell the spike when the rpm limiter cuts in,so I'am presuming its a hot rod six ? Only guessing ? but do too much of that (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) . |
falcor75 |
May 28 2018, 11:51 PM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on.
porschetub |
May 29 2018, 12:21 AM
We still don't know what motor it is ?.
sharper |
May 29 2018, 05:42 AM
wndsrfr |
May 29 2018, 06:11 AM
Senior Member Group: Members Posts: 1,429 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on. (IMG:style_emoticons/default/agree.gif) get the data they stored on the runs and print out the air/fuel lambda curve on the chart....nice flat torque profile but shouldn't dip off...could prolly go to 6800 safely also.... |
sharper |
May 29 2018, 08:13 AM
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on. (IMG:style_emoticons/default/agree.gif) get the data they stored on the runs and print out the air/fuel lambda curve on the chart....nice flat torque profile but shouldn't dip off...could prolly go to 6800 safely also.... Not sure they have that. It was just a promotional day where they did three quick runs. They only tapped into the MSD box to get the tach reading. |
falcor75 |
May 29 2018, 08:22 AM
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on. (IMG:style_emoticons/default/agree.gif) get the data they stored on the runs and print out the air/fuel lambda curve on the chart....nice flat torque profile but shouldn't dip off...could prolly go to 6800 safely also.... Yes if it's a 3,5 with 3,2 fueling you are probably a bit lean where the curves dip, you should be able to get that taken care of. I'm not sure if Steve Wong has something or not, I used his chip in my 964 and got 252 hp at the wheels. |
JmuRiz |
May 29 2018, 08:46 AM
914 Guru Group: Members Posts: 5,426 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on. (IMG:style_emoticons/default/agree.gif) get the data they stored on the runs and print out the air/fuel lambda curve on the chart....nice flat torque profile but shouldn't dip off...could prolly go to 6800 safely also.... Yes if it's a 3,5 with 3,2 fueling you are probably a bit lean where the curves dip, you should be able to get that taken care of. I'm not sure if Steve Wong has something or not, I used his chip in my 964 and got 252 hp at the wheels. (IMG:style_emoticons/default/agree.gif) With a proper tune, that engine will really wake up! Area under the curve and peak should increase. Check with Steve and tell him the specs of your c:r and cam and you should get a boost. He may suggest new injectors too. |
ConeDodger |
May 29 2018, 11:05 AM
Apex killer! Group: Members Posts: 23,587 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on. (IMG:style_emoticons/default/agree.gif) get the data they stored on the runs and print out the air/fuel lambda curve on the chart....nice flat torque profile but shouldn't dip off...could prolly go to 6800 safely also.... Yes if it's a 3,5 with 3,2 fueling you are probably a bit lean where the curves dip, you should be able to get that taken care of. I'm not sure if Steve Wong has something or not, I used his chip in my 964 and got 252 hp at the wheels. (IMG:style_emoticons/default/agree.gif) With a proper tune, that engine will really wake up! Area under the curve and peak should increase. Check with Steve and tell him the specs of your c:r and cam and you should get a boost. He may suggest new injectors too. That motor is underdeveloped. My first impression was WTF is going on between 5-6K HP? That HP curve should not be dipping in the middle of the run. Best possible solution would be to bring it out to Steve and have him tune it on the Dyno and burn a custom chip. But calling him will get you into the ballpark. Others are probably right, I’d guess you’re going lean in that dip. A stock well-tuned 3.2 will do 165-170 peak HP with driveline losses. You’ve probably got 10-15 HP waiting for you. Plus, that dip is dangerous for the motor if it is going lean. (IMG:style_emoticons/default/sad.gif) |
sharper |
May 29 2018, 05:13 PM
Thanks for all the suggestions. I knew it needed to be tuned for my set up and this was just the baseline to start.
burton73 |
May 29 2018, 05:46 PM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Get a custom Steve Wong chip and you will increase the power by 30-35 HP and it will just feel better.
Bob B (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/w00t.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 02:36 AM |
