QUOTE(JmuRiz @ May 29 2018, 11:46 AM)
QUOTE(falcor75 @ May 29 2018, 06:22 AM)
QUOTE(wndsrfr @ May 29 2018, 02:11 PM)
QUOTE(falcor75 @ May 28 2018, 09:51 PM)
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on.
get the data they stored on the runs and print out the air/fuel lambda curve on the chart....nice flat torque profile but shouldn't dip off...could prolly go to 6800 safely also....
Yes if it's a 3,5 with 3,2 fueling you are probably a bit lean where the curves dip, you should be able to get that taken care of. I'm not sure if Steve Wong has something or not, I used his chip in my 964 and got 252 hp at the wheels.
With a proper tune, that engine will really wake up! Area under the curve and peak should increase. Check with Steve and tell him the specs of your c:r and cam and you should get a boost. He may suggest new injectors too.
That motor is underdeveloped. My first impression was WTF is going on between 5-6K HP? That HP curve should not be dipping in the middle of the run. Best possible solution would be to bring it out to Steve and have him tune it on the Dyno and burn a custom chip. But calling him will get you into the ballpark.
Others are probably right, I’d guess you’re going lean in that dip.
A stock well-tuned 3.2 will do 165-170 peak HP with driveline losses. You’ve probably got 10-15 HP waiting for you. Plus, that dip is dangerous for the motor if it is going lean.
