GT style cockpit oil line cover. |
mb911 |
May 31 2018, 09:11 AM
914 Guru Group: Members Posts: 6,823 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
11tenths |
May 31 2018, 09:34 AM
Ve get too soon old, und too late schmart Group: Members Posts: 142 Joined: 11-October 12 From: Islip, Long Island, NY Member No.: 15,026 Region Association: North East States |
porschetub |
May 31 2018, 03:56 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
r_towle |
May 31 2018, 05:45 PM
Custom Member Group: Members Posts: 24,573 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I was thinking the same thing. Might want to consider a double walled version to make sure you don't get burned. Also so fresh air ducted through that new cavity. |
mepstein |
May 31 2018, 06:04 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I was thinking the same thing. Might want to consider a double walled version to make sure you don't get burned. Also so fresh air ducted through that new cavity. I think you all are trying to make this more complicated than it needs to be. If the metal does get hot, just add some heat wrap to the outside and maybe inside or wrap the lines, or both. The heat wrap that is used for exhaust is cheap and effective. 16’ of 2” exhaust wrap - $10 at walmart https://www.walmart.com/ip/Yescom-2-16-4ft-...13=&veh=sem Attached image(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 08:33 AM |
