Dash Face plate help!, Stuck with a lighter ??? |
Moose01 |
Jun 1 2018, 09:28 AM
Newbie Group: Members Posts: 15 Joined: 14-November 10 From: Houston, Tx Member No.: 12,386 Region Association: None |
Hello,
After years of looking at the horrible wood added to my dash face I ripped it all off! The radio plate is or was damaged, its old a cracked. I removed the metal face plate and ordered a new "one" from a vendor. I have the correct material as well, all good right? ... I managed to remove all of the switches, not sure if I can actually reinstall them. However I cannot get the lighter out! I did remove the wiring which was a ****! The lighter is now "free", hanging in the hole, but I cannot get it out of the dash. I cut the old face plate off! How can I get the lighter housing out and then reinstall? There must be something simple I am missing?? Also the small "handle" for the glove box door is missing, any idea where I can get another one? I have tried the usual suspects for parts to no avail. I might just make one. Thanks Chris Any other 14 guys in Houston? |
gcrotvik |
Jun 1 2018, 09:56 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
In the early cars, the lighter has a flat metal retaining spring(ish) clip that slides up tight to the back side of the dash. It's a bitch to get off. In the late cars (74 or so) the lighter has a spring that slides down the outside of the lighter tube and has a clip holding the spring in place near where the hot/ground leads connect. Turn the clip until it unlatches and slides off, releasing the spring and the lighter tube.
Attached image(s) |
Lo-Fi Version | Time is now: 20th May 2024 - 02:23 AM |
