Foglights in a75/76 with backdated bumpers |
DickSteinkamp |
Jun 1 2018, 05:19 PM
Senior Member Group: Members Posts: 500 Joined: 27-February 17 From: Bellingham, WA Member No.: 20,876 Region Association: None |
Has anyone installed the stock, early foglights in a 75/76 backdated with the early, chrome bumpers?
I can locate where the hole goes in the front panel to mount them, but there is no way (that I can find) to get behind the panel in that location with a nut to secure the bolt. Thanks. |
Porschef |
Jun 1 2018, 06:48 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Yes, I did it, using a nutsert.
I can take pics in the morning, shoot me a pm to trigger my memory.. (IMG:style_emoticons/default/blink.gif) |
DRPHIL914 |
Jun 2 2018, 01:09 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i will be doing this very soon also, so i am interested in how to go about doing it as well
rgalla9146 |
Jun 2 2018, 06:08 AM
Yes, I did it, using a nutsert. I can take pics in the morning, shoot me a pm to trigger my memory.. (IMG:style_emoticons/default/blink.gif) Joe has the right idea. Very handy tool but sort of spendy for a single use..... try to borrow one ? $80 on Amazon Attached thumbnail(s) |
rhodyguy |
Jun 2 2018, 07:18 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,071 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Handy tool.
Porschef |
Jun 2 2018, 07:32 AM
Ok, so I went back to review my post about backdating here
http://www.914world.com/bbs2/index.php?sho...+long+BUB's and found that I had already installed the fogs and horns prior to the final installation of bumpers. Couldn't remember what I did, heck, I can barely remember what I had for dinner last night; wait, it was fluke fillet with a white wine/caper sauce, mmmmmmm, delicious, but alas, I digress. Anyway, thanks to the search feature here, there is a flat area below where the light goes that I drilled in the center. It must've worked out well 'cause the lights pretty much were centered when I installed the bumper assembly. You don't need a fancy tool to install the Nutsert, there's one that looks like a bolt with a nut that gets tightened after the Sert is placed into the hole, effectively mushrooming out the back and locking the Sert into position. Now to go out to the complete Hell Hole that is my garage and see if I can find it. Stay tuned... |
Porschef |
Jun 2 2018, 08:03 AM
Ok, so I found it. Will wonders ever cease...
It's placed between the Sert and the bolt, the side with the groove up against the Sert, the Sert goes in the hole, the bolt is tightened and this is held in place with another wrench to keep it and the Sert from spinning. Then the Sert mushrooms up against the back of the hole. Once locked in place, the bolt is removed, the little tool is removed, and the bolt goes back into the Sert. Be sure to drill the appropriate sized hole for the nutsert, it should be just tight enough that the Sert doesn't spin at all when placed in there and is actually subject to an interference fit. This is to ensure is that the tool will work properly, and once that Nutsert is locked into place, it's pretty permanent. HTH, Joe |
Porschef |
Jun 2 2018, 08:07 AM
Phil, have you ever eaten at Martha Lou's kitchen in Charleston?
DickSteinkamp |
Jun 2 2018, 09:20 AM
Thanks Porschef and all others. It's nice to know I won't be re-inventing the wheel.
Do you remember where you got your nutserts, Porschef? The mechanicals are pretty much done on mine. It's running and driving nicely. Time to do the fun stuff like this to trim it out. Then another complete tear down for body and paint. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-20876-1527952799.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-20876-1527952799.2.jpg) |
Steve |
Jun 2 2018, 10:19 AM
914 Guru Group: Members Posts: 5,570 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I used the same tool and did rivnuts on mine also. I’ve used rivnuts for lots of stuff on my 914.
ConeDodger |
Jun 2 2018, 01:04 PM
Apex killer! Group: Members Posts: 23,573 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
McMark did mine. Drilled a hole big enough to seat a flange nut with the flat side out. Then welded it in place. Grind off the weld and mount the lights...
DickSteinkamp |
Jun 2 2018, 01:19 PM
These guys have the tool and the rivnuts...
Rivnut Tool (IMG:http://www.914world.com/bbs2/uploads_offsite/glhblob1.blob.core.windows.net-20876-1527967194.1.jpg) Rivnuts (IMG:http://www.914world.com/bbs2/uploads_offsite/glhblob1.blob.core.windows.net-20876-1527967196.2.jpg) The tool is only $7.15 and the rivnuts are about $1 each. I ordered 4 each of steel and aluminum. I'm going to practice a little first. I'd prefer to use the steel if the test with them on a piece of scrap goes OK. |
flmont |
Jun 2 2018, 03:33 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I be like'in those rims....new style fuchs,..??
DRPHIL914 |
Jun 2 2018, 04:49 PM
Phil, have you ever eaten at Martha Lou's kitchen in Charleston? i am not sure, when our oldest daughter was at College of Charleston couple years ago we went to a lot of places- there are a lot of great places to eat!! only one we went to a few times was a french restaraunt my wife and daughters really liked down on king st i think- |
Porschef |
Jun 3 2018, 08:01 AM
Picked to have the best fried chicken in the country by the Food Network. My wife and daughter ate there a couple years back when they went to check out a couple schools in SC; they said it was fantastic. Just a little roadside place that's been pumping out the stuff for years. Disappointed I've never been.
Me, "I eat mo' chicken any man eva' seen" |
rhodyguy |
Jun 4 2018, 08:45 AM
cause I'm you backdoor man...
Porschef |
Jun 4 2018, 06:23 PM
Haha, I knew someone would pick up on that..
Nice work Kevin... (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:53 PM |
