FS L rear suspension consoles, cowl, tail panel, driver side rear suspension consoles, tail panel |
marksteinhilber |
Jun 1 2018, 05:46 PM
Member Group: Members Posts: 229 Joined: 18-October 12 From: Foothill Ranch, CA 92610 Member No.: 15,057 Region Association: Southern California |
Good California donor car parts:
1. Both inner and outer rear driver side suspension consoles. $180 shipped in US. I will further cut them out from the frame with a cutoff wheel unless you prefer local pickup. You get to drill out the spot welds, or weld in the complete section. 2. Front windscreen cowl corners. some rot, but each allows you to pre-build your own repair part without starting from scratch. Good for fixing rotted front trunk gasket channel. $25 for the pair plus shipping 3. Tail panel - local pickup Los Angeles/Orange County area only. Makes fixing a dent or rusted out panel easy. has some of trunk floor and heat shield. $100 |
Lo-Fi Version | Time is now: 22nd May 2024 - 03:18 AM |
