Do fuel pumps get hot? |
BCinSC |
Jul 12 2003, 12:37 PM
Nothing but Trouble Group: Members Posts: 138 Joined: 8-June 03 From: Wakefield, MA Member No.: 800 Region Association: North East States |
I've replaced my leaking OEM pump with a nice MSD unit that works great, but is louder than original (though that may because I mounted to firewall, for lack of better alternative). Can I wrap some high-temp dynamat around it?
BCinSC |
Jul 12 2003, 01:30 PM
High Pressure Electric Fuel Pump
Multiport EFI systems require a stable fuel supply to maintain best performance throughout the engine’s rpm range. This high pressure and high flow Fuel Pump features a roller vane pump mechanism which is extremely resistant to clogging and jamming. The pump mounts in-line (out of the fuel tank) with two supplied cushioned clamps for a quick and sturdy installation. The nipple inlet is 3/8” with a 5/16” outlet. The wire terminals feature brass studs for secure connections. Made in the USA, the pump is ideal for use as a “booster” for nitrous oxide applications, or as a stand alone pump for multiport EFI systems on engines up to approximately 500 HP. Capable of 43 gph at 40 psi/162l/h. |
anthony |
Jul 12 2003, 02:02 PM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
Why do you cross post your questions to Pelican and Rennlist? I think it's best to start in your favorite forum and then post elsewhere if you don't get a good answer.
MarkV |
Jul 12 2003, 02:16 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
Hot enough that the factory pump uses fuel to cool it. It is recommended that you don't run the pump dry, as the heat generated can damage the pump. (IMG:style_emoticons/default/w00t.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 05:41 AM |
