BCinSC
Jul 12 2003, 12:37 PM
I've replaced my leaking OEM pump with a nice MSD unit that works great, but is louder than original (though that may because I mounted to firewall, for lack of better alternative). Can I wrap some high-temp dynamat around it?
BCinSC
Jul 12 2003, 01:30 PM
High Pressure Electric Fuel Pump
Multiport EFI systems require a stable fuel supply to maintain best performance throughout the engine’s rpm range. This high pressure and high flow Fuel Pump features a roller vane pump mechanism which is extremely resistant to clogging and jamming. The pump mounts in-line (out of the fuel tank) with two supplied cushioned clamps for a quick and sturdy installation. The nipple inlet is 3/8” with a 5/16” outlet. The wire terminals feature brass studs for secure connections. Made in the USA, the pump is ideal for use as a “booster” for nitrous oxide applications, or as a stand alone pump for multiport EFI systems on engines up to approximately 500 HP. Capable of 43 gph at 40 psi/162l/h.
anthony
Jul 12 2003, 02:02 PM
Why do you cross post your questions to Pelican and Rennlist? I think it's best to start in your favorite forum and then post elsewhere if you don't get a good answer.
MarkV
Jul 12 2003, 02:16 PM
Hot enough that the factory pump uses fuel to cool it. It is recommended that you don't run the pump dry, as the heat generated can damage the pump.
