FS: Used Patrick Motorsports Fuel Cell, sold and shipped to Larry |
Steve |
Jun 4 2018, 12:17 PM
914 Guru Group: Members Posts: 5,580 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
For Sale: Used Patrick Motorsports Fuel Cell.
$650.00 or best offer Purchased and installed by Otto's March 2006. Bladder is original. The bladder holds 10 gallons. I was told by fuel safe the bladder replacement is only available from Patrick Motorsports. I was told its around $1k for a replacement. I would call to make sure. Here is a link to the PMS page for more information. http://www.patrickmotorsports.com/part/por...tank-10-gallon/ |
GregAmy |
Jun 5 2018, 07:13 AM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Can you pull and offer pics of the bladder/condition? SCCA no longer mandates the 5-year replacement ("Fuel cells do not time out and have no expiration date.") In reality, most orgs don't actually enforce it because it's such a PITA to pull bladders to verify the dates. It's probably a case of "looks good, looks safe, it's your ass go have fun."
More importantly, however, I'm not seeing on Patrick's web site where this cell carries the required FIA or SFI certification. SCCA's regs: "All safety fuel bladders shall be constructed and certified in accordance with the FIA FT-3 or higher (FT-3.5, FT- 5, etc.) or SFI 28.3 specifications. Fuel cells do not time out and have no expiration date. Alternatively, safety fuel cells shall be constructed in accordance with FIA FT-3 or higher or SFI 28.3 specifications and tested to those requirements by an independent facility as witnessed and certified by a Professional Engineer." Were I doing things all over again, I'd go this direction instead of a cell mounted up front in the trunk area. SCCA actually allows use of the stock tank because "stock fuel tank is located between the axle center lines and within the main chassis structure". If you an demonstrate that the bladder is actually in good shape, you may have a larger customer base for it. |
Steve |
Jun 5 2018, 07:42 AM
Can you pull and offer pics of the bladder/condition? SCCA no longer mandates the 5-year replacement ("Fuel cells do not time out and have no expiration date.") In reality, most orgs don't actually enforce it because it's such a PITA to pull bladders to verify the dates. It's probably a case of "looks good, looks safe, it's your ass go have fun." More importantly, however, I'm not seeing on Patrick's web site where this cell carries the required FIA or SFI certification. SCCA's regs: "All safety fuel bladders shall be constructed and certified in accordance with the FIA FT-3 or higher (FT-3.5, FT- 5, etc.) or SFI 28.3 specifications. Fuel cells do not time out and have no expiration date. Alternatively, safety fuel cells shall be constructed in accordance with FIA FT-3 or higher or SFI 28.3 specifications and tested to those requirements by an independent facility as witnessed and certified by a Professional Engineer." Were I doing things all over again, I'd go this direction instead of a cell mounted up front in the trunk area. SCCA actually allows use of the stock tank because "stock fuel tank is located between the axle center lines and within the main chassis structure". If you an demonstrate that the bladder is actually in good shape, you may have a larger customer base for it. |
larryM |
Jun 6 2018, 09:14 PM
emoze Group: Members Posts: 891 Joined: 1-January 03 From: mid- California Member No.: 65 Region Association: Northern California |
PM sent
GregAmy |
Jun 7 2018, 06:29 AM
I'll pull it apart this weekend, but I did install a clear fuel filter between the tank and pump... What you're looking for is the quality of the rubber itself. Look at the color; is it still that creamy color or is it turning brown/-er/-ish? Look outside and inside; are there cracks in the rubber? Any obvious delamination in the layers or the seams? If the bladder has been stored inside a climate-controlled space all of its life (no Minnesota winters and/or Florida summers in the open garage), looks good per the above, and was not in constant contact with old fuels (esp alcohol) then it's likely safe for use. Some orgs do require replacement after 5 years, but as noted in my above post unless there's a sticker outside (which you can remove) confirming the date of the bladder itself, there's just no reasonable way for tech inspectors to check it at the track. Some will ask you to pull it for inspection at the annual check, but that's rare. Replace the foam, though; that stuff degrades quickly and makes a friggin mess. And it's relatively cheap. - Greg |
gereed75 |
Jun 7 2018, 09:05 AM
Senior Member Group: Members Posts: 1,245 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
As a data point -
Not sure if this bladder uses the same material or not but I just pulled and inspected the bladder and foam in my vintage race car. The black rubber bladder and purple foam were pristine. This is an ATL cell......built in 1985. |
Steve |
Jun 8 2018, 10:07 AM
Lo-Fi Version | Time is now: 9th May 2024 - 11:15 AM |
