23 Pages V « < 5 6 7 8 9 > »
> Travis' 72 914-6 Conversion
TravisNeff
post Jul 14 2018, 06:37 PM
Post #121
Easy come, easy go. I sold the SRP bar to Hans and have the Welt bar in the classifieds. I didn't understand that the hollow 25mm bar is the same stiffness as my solid 22 bar.
I ordered a 32mm .095 bar from Tangerine Racing.
I was able to patch where I had the crack in the frame rail on the drivers side. I will add a reinforcement to this area on both the driver and passenger side.
TravisNeff
post Jul 14 2018, 06:40 PM
Post #122
forgot a pic.. When I weld this in it will tie right to the existing stiffening kit in the corner, along the seam of the inner side of the frame rail and wrap up to the heater duct. I will worry about the engine compartment side at a later time. Need to get this in so I can move on with the floor replacement.
I am also cutting about an inch up on the lower firewall and patching that area before the floors go in.
TravisNeff
post Aug 20 2018, 11:40 AM
Post #123
Not much to report on progress.
I have the floors partially done, the perimeter welds are in, still need to plug weld along the interior and do the butt weld from old floor to new.
Jamie Rust sent me a little gift, a 5 lug spare. I probably would have driven around without one until I learned my lesson the hard way, I appreciate the gift!
I also received new SS fuel lines and a tangerine shift linkage kit,. I picked up some Monoballs for the front struts that I found in the classifieds here.
mb911
post Aug 20 2018, 02:20 PM
Post #124
Very cool. I need to get a 5 lug spare as well..
TravisNeff
post Sep 4 2018, 11:38 AM
Post #125
Engine shelf is in.
mb911
post Sep 4 2018, 03:17 PM
Post #126
QUOTE(TravisNeff @ Sep 4 2018, 09:38 AM) *
Engine shelf is in.
Funny mine is just like that. I feel its strange that part doesn't have the channel for the rubber that goes all the way to meet the front corner.
TravisNeff
post Sep 16 2018, 05:32 PM
Post #127
As you can see the in the pic above, the trunk pivot looks like a booger farm.
Lots of braze and some weld, looks like this was attempted to be repaired a couple of times. Good thing I took this out, it was cracked and smashed.
The wall behind the pivot has given way and I will need to patch. I am a bit worried about access and needing that patch to not fail in the future.
TravisNeff
post Sep 16 2018, 06:22 PM
Post #128
Hole cut. I smoked my dremel with the flexi wand and had to finish with a cutoff wheel.
TravisNeff
post Sep 29 2018, 12:59 PM
Post #129
Hinge patch piece is in and the hinge is as well.
Moving onto reinforcing the frame rail in the engine compartment. I wasn't sure about recreating the -4 mount divot, but went for it. Turned out decent enough that it wont go in the scrap pile. I will go around the bottom of the frame rail and make the remainder of the divot there, I think it will be easier to do. Then weld the 2 pieces together as one - then hot glue it into the car.
I am not going to commit to welding this in unless I can get the drivers side to turn out the same.
TravisNeff
post Sep 29 2018, 03:42 PM
Post #130
2nd one done
TravisNeff
post Sep 30 2018, 05:48 PM
Post #131
Driver side is complete. I was going to recreate the divot piece entirely, but I think I will leave it like this and stitch it on in. Bending a very small peice of 14g into a cup shape and have it fit, then trim to size sounds like a half day ordeal for my skillset.
bbrock
post Sep 30 2018, 05:52 PM
Post #132
Good call! I had to recreate those $%^#ing divots on both sides and it was no fun. I need the 4-banger mounts so no other option. Then I got to cut one of them open and do it again when it was time to reinstall the mount because I didn't get it quite right. The less you have to do with those divots, the better. Fantastic work. Enjoying watching the progress. (IMG:style_emoticons/default/beerchug.gif)
TravisNeff
post Sep 30 2018, 05:53 PM
Post #133
In place
TravisNeff
post Sep 30 2018, 05:54 PM
Post #134
Thanks Brent, I appreciate the kind words. This turned out better than I expected.
bbrock
post Sep 30 2018, 06:00 PM
Post #135
QUOTE(TravisNeff @ Sep 30 2018, 05:54 PM) *
BTW, because that divot is a double walled dome, it is already hell for stout. I wailed on one with a small sledge trying to nudge it just a little to allow installing my mount. It didn't budge. Your reinforcement is tying right into the strongest part so trying to fill that in would have been a waste of time IMHO. Looks fantastic!
mb911
post Sep 30 2018, 07:04 PM
Post #136
Looks very similar to what I did..
TravisNeff
post Sep 30 2018, 07:44 PM
Post #137
QUOTE(mb911 @ Sep 30 2018, 06:04 PM) *
Yep, you started it.. (IMG:style_emoticons/default/poke.gif)
mb911
post Oct 1 2018, 06:53 AM
Post #138
QUOTE(TravisNeff @ Sep 30 2018, 05:44 PM) *
You took better pictures.. I also used 14ga from memory.
TravisNeff
post Oct 2 2018, 09:58 PM
Post #139
Finished making the passenger side reinforcement. Got most of the driver's side welded in. I had a few challenges with weld contamination, otherwise it's ok. I will finish this up tomorrow and then onto the other side.
TravisNeff
post Oct 6 2018, 03:48 PM
Post #140
Hijacking my own thread. Did a distributor rebuild for the SC and new bronze shift coupler bushings. The car has been running hot and takes its time getting back to idle from cruise once warm, at 94k miles it was time.
I got a nice kit from PartsKlassic for the rebuild. I hope i didnt jack anything up
- Lo-Fi Version Time is now: 3rd July 2026 - 07:54 AM
