23 Pages V « < 6 7 8 9 10 > »
> Travis' 72 914-6 Conversion
TravisNeff
post Oct 8 2018, 02:37 PM
Post #141
I got both reinforcements welded in, in the engine compartment.
I needed to find something to do for my lunch hour. I have the reinforcement plates for the front swaybar from Maddog. They are 16g, I used them as a template and made a pair out of my leftover 14g. Overkill? maybe. I want to run a smaller torsion bar and a big swaybar, and why the hell not. Plus I had to hog out the swaybar hole for the 31mm bar. i hope to get that this week! Excited about that.
mb911
post Oct 8 2018, 02:59 PM
Post #142
I made my own stiffness out 14 ga for everything. I like the way you think.
TravisNeff
post Oct 8 2018, 03:04 PM
Post #143
Giddyup! I don't feel so foolish now (IMG:style_emoticons/default/smile.gif)
sixnotfour
Post #144
SC distr. rotate the wrong way wont go in your 2.4
end of hyjack
TravisNeff
post Oct 8 2018, 03:07 PM
Post #145
That's good, I put it back into the SC. Got lucky and fired up on the first try and runs much better at low rpms. I have a 123 distributor for the 2.7
ChrisFoley
post Oct 8 2018, 03:19 PM
Post #146
I am Tangerine Racing
I think those plates are overkill at 16ga.
TravisNeff
post Oct 8 2018, 03:31 PM
Post #147
hmmm
sixnotfour
post Oct 8 2018, 03:51 PM
Post #148
have you drilled your door handles yet...if not no worries on weight
TravisNeff
post Oct 8 2018, 03:53 PM
Post #149
I was gonna take out the handles completely and use a piece of rope with a knotted end.
TravisNeff
post Oct 13 2018, 12:34 PM
Post #150
I shitcanned the front reinforcements. The maddog ones and the ones I made needed some extra trimming to make it fit. I had previously welded in the backing plates and fixed the crack in the tub, from the old swaybar that didn't have the backing plates. We will see how it goes as is.
I also traded out my 22mm torsion bars with Yeahmag for his 21mm bars.
When I pulled the front struts away to open up the swaybar holes I found that one of my Koni's had bit the dust. I bought them 15 years ago and don't have a receipt for a warranty rebuild. I will have to find someone who can rebuild them for me, I hear that not many places rebuild the Koni's and the wait time is pretty long.
I got a surprise from Tangerine Racing this morning.
ChrisFoley
post Oct 13 2018, 01:20 PM
Post #151
There's a trick to setting up the anti-sway bar so there's no binding. Doing this will go a long way to preventing stress cracks in the future.
Bolt up both bushing brackets and slide the bar in until it nearly touches the other side. Determine which way it needs to be moved to line up perfectly. Pull the bar back out most of the way and lean on it in the direction needed to bend the chassis so next time you slide it in it will go right into the other bushing. It may take 2 or 3 tries to line it up just right. Then follow the same procedure from the other side of the car.
After doing this it should be possible to rotate the bar by hand after it's fully inserted - without the arms attached.
Put some bearing grease on both bushings when you're ready to permanently install the bar.
TravisNeff
post Oct 13 2018, 01:22 PM
Post #152
That'll work, I am super excited about this bar.
Thanks Chris, I just have it finger tight and it seems just about right - I will heed your advice when I bolt her down.
TravisNeff
post Oct 13 2018, 08:00 PM
Post #153
Firewall forward mount for the suspension brace.
TravisNeff
post Oct 13 2018, 09:00 PM
Post #154
I made a plate that wraps around the front of the suspension console and glued in the bracket.
mb911
post Oct 14 2018, 06:17 AM
Post #155
Travis your welds are really shaping up.. Good job.
TravisNeff
post Oct 14 2018, 01:18 PM
Post #156
Thanks for the vote of confidence Ben. It's in, had a couple blown holes that I need to fix.
TravisNeff
post Oct 14 2018, 07:26 PM
Post #157
Moving onto the inside. The car was crashed at some point and the hump below the seat belt pocket was crushed up pretty good. Hardly noticeable when the relay board was in place. I was able to beat it mostly back into shape, but have a crack in the metal. This is going to be a bit tricky for me to make a patch piece.
TravisNeff
post Oct 14 2018, 08:16 PM
Post #158
Starting of the patch piece.
bbrock
post Oct 14 2018, 08:25 PM
Post #159
That's an impressive start! You are doing better than me. I had to patch the little bulge where the hood release pull attaches which is a similar PITA dome. I wound up having to make a relief cut to pull the metal around to form the dome. Nice work on yours! (IMG:style_emoticons/default/smilie_pokal.gif)
TravisNeff
post Oct 14 2018, 09:49 PM
Post #160
Thanks Brent, got lucky with this part. A little closer now.
- Lo-Fi Version Time is now: 3rd July 2026 - 09:07 AM
