23 Pages V « < 8 9 10 11 12 > »
> Travis' 72 914-6 Conversion
mb911
post Oct 28 2018, 09:46 AM
Post #181
Travis looks great.. Good job.
bbrock
post Oct 28 2018, 12:06 PM
Post #182
I have to admit, after replacing a rusting frunk pan, it makes me cringe to see a perfectly good trunk cut open, but you did this one proud. (IMG:style_emoticons/default/thumb3d.gif)
As for using a shrinking disc, a monkey can do it. I'm proof of that!
TravisNeff
post Oct 29 2018, 10:05 PM
Post #183
Thanks for the kind words and advice everyone, I appreciate it.
I ordered a shrinking disk and it should get here by the weekend. In the meantime I took Chris' advice and I hammered and dollied the perimeter weld lines. Amazing that you relieve a little of tension and the floor starts to firm up. I ended up with a few more waves than when I started. I am not worried and believe that I can get it all straight in the end.
I also welded in a cross brace and a 16g plate underneath. I was able to save my tow hook and will weld that on the bottom of the floor. There is no interference with the lower duct and it is all hidden away.
TravisNeff
post Nov 1 2018, 10:06 PM
Post #184
I ventured into the unknown. Not many people share pics of the frame rail penetration from all angles. I started with 2 1.5" holes stacked. Turns out where I cut on the outside was close, but didn't match the inside. Also I did not cut far forward enough to clear the J tube.
Time to make lemonade. I ground down the flange on the front of the J Tube. Then enlarged the holes a little bit, and then a bit more. I will have to patch where I did my exploration cuts.
I made a rectangular duct and had the idea that I could build in a splash shield along the front. Both -12 hoses fit, fittings passing through will be tight, but not impossible
TravisNeff
post Nov 2 2018, 03:54 PM
Post #185
I think I am turning into one of them tweakers.
914forme
post Nov 3 2018, 07:35 AM
Post #186
Welcome to the dark side of this hobby. (IMG:style_emoticons/default/happy11.gif) You by no means have it as bad as some of us. Your new in this journey and well their are lots of us here to help you transgress into a make 3 times sort of guy, and never be quite satisfied with the end result.
I will give you a hint here! Make it once, get it on the car, move on to the next thing. There is always time to go back and redo it. Or you might not have to (IMG:style_emoticons/default/confused24.gif) because the joy of driving might just replace the joy of perfections.
It will never be perfect, it will never meet your own standards, it will never meet the standards of the Instagram trolls who see a perfect Weave TIG weld in Titanium and wonder why they can't do that with a MIG, when they have only welded for 2 weeks tops in total pull the trigger time.
I want to say thank you for posting the details, the good and the bad, being willing to put it out there. As of today I will not get any 914 work done. So I am living via build threads like these. Thank you for putting it out here, thank you for taking the risk and asking the questions. Thank you for allowing us to be part of your journey. Enjoy the ride.
I do have a bit of fabrication and welding in my plans for today. But that involves putting a new discharge shoot on the 72" zero turn that I am re-powering also. Yes I do engine swaps on my power equipment also. I got it bad, maybe I need to bolt something on one of my 914s.......
mb911
post Nov 3 2018, 08:15 AM
Post #187
QUOTE(914forme @ Nov 3 2018, 05:35 AM) *
And yes Stephen bolt something on the 914..
TravisNeff
post Nov 3 2018, 02:33 PM
Post #188
Thanks for the encouragement Stephen. The further along I go, I keep repeating myself "nothing is perfect" and keep the momentum going.
Patched in the extra cutout. A 3" piece of PVC pipe I had laying around is just about right for replicating the bent around the corner of the tub. Had to trim the patch piece to fit the rectangular tube.
Cleaned up the welds on my tweaker tube and its about ready to be glued in. Amazing that this started out a flat piece of sheet metal.
TravisNeff
post Nov 3 2018, 05:15 PM
Post #189
Lets see if the lines fit. I first cut the fuel evap holes into a big oval, that seemed to work ok. The turn after the first sill support to penetrate the cabin didn't make me feel all squiggly inside, so I cut the support out. It had some rust going on anyways, so I shed no tears.
bbrock
post Nov 3 2018, 05:26 PM
Post #190
You HAVE to be happy with that!
TravisNeff
post Nov 3 2018, 05:43 PM
Post #191
Yes I am very happy, its the coolest goddamn thing I have done so far.
live free & drive
post Nov 3 2018, 06:08 PM
Post #192
You might try some of these PEX metal 90deg bend supports they will keep your hose from flattening and losing sectional area:
https://www.pexsuperstore.com/pex-accessori...ort-elbows.html
They also come in 5/8"
a 1" will take 1.5 OD tubing - 3/4" takes 1"OD tubing etc. They can be put on and taken off in situ.
Several companies make them the Uponor brand is probably best; below is a 3/4" support, they lock on with friction:
sixnotfour
post Nov 3 2018, 10:32 PM
Post #193
https://www.summitracing.com/parts/ear-773412erl/overview/
Earl's Performance Hose Inner Support Springs
914forme
post Nov 4 2018, 08:44 AM
Post #194
Okay learned something new today, Never thought that SS line would collapse in a tight bend. I knew they had a recommended bend radius.
Filled away
TravisNeff
post Nov 4 2018, 10:48 AM
Post #195
I am not sure what you guys are saying.
One post is saying I should look at external strain relief to make that 90 degree bend.
The next post I think is being stated that an internal wire strain relief is what you want, rather than external. But not specifically that I need any strain relief at all (for either post).
Minimum bend radius for -12 standard braided hose is 4.5 inches. What the hell does that mean? I have no clue so I looked it up.
=90/360*2*3.14*4.5 Which comes out to 7.065 inches of length required to make a 90 degree bend. I am not sure if this is right or not.
TravisNeff
post Nov 4 2018, 11:02 AM
Post #196
Attempting to measure my overall length of the bend.
sixnotfour
post Nov 4 2018, 11:27 AM
Post #197
I am implying its the rubber that will collapse, that is why you support from the inside ... you will probably be fine..but cheap insurance...
I know alot of peeps have never had a problem... esp with new line and its basically a push system..no sucking
made you (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/happy11.gif) 7.0675
TravisNeff
post Nov 4 2018, 11:32 AM
Post #198
I agree that would be cheap insurance. I just don't know how I would fish that wire down 3-4 feet of hose, that bend is right in the middle of the run. You monkeys had me up worrying about it all night and first thing this morning (IMG:style_emoticons/default/laugh.gif) I then realized that maybe I should try and find out if I need it at all.
sixnotfour
post Nov 4 2018, 11:38 AM
Post #199
(IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/stirthepot.gif)
bbrock
post Nov 4 2018, 11:42 AM
Post #200
QUOTE(TravisNeff @ Nov 4 2018, 11:32 AM) *
I'm a little confused about why it has to be an internal spring. In order to collapse, the cross section of the hose has to oval. I would think a strong spring tightly fitting the outside diameter of the hose should keep the cross section of the bend round and free flowing just as well, maybe even better since there is nothing inside restricting flow. I've seen that approach used in other applications. A quick Google turned up these: https://www.new-line.com/clamps/hose-wrap-s...tainless-spring Might be an alternative? (IMG:style_emoticons/default/confused24.gif)
- Lo-Fi Version Time is now: 3rd July 2026 - 10:16 AM
