23 Pages V « < 11 12 13 14 15 > »
> Travis' 72 914-6 Conversion
bbrock
post Nov 20 2018, 08:04 PM
Post #241
QUOTE(TravisNeff @ Nov 20 2018, 06:31 PM) *
I am having no fun with this patch. I did get a bunch of the crinkled up metal in other areas fairly straight though.
If you see where I cut, I left a the lip of the indent and was going to weld to that.
Well it was like a game of whack a mole blowing holes along the whole damn thing as the metal was too thin and I was set too hot on the welder. When i got the metal finally all glued down the indent along the middle was pretty much flat along the bottom seam
I don't care too much if it is ugly in the interior, it will be covered. Would like it to look a little more seamless in the engine bay. I am thinking this is a cut out and do-over, I could extend a couple inches along the indent as I found some more pitted metal when I stripped all the por15 off.
Stop! You are giving me flashbacks. (IMG:style_emoticons/default/lol-2.gif) Boy does that sound familiar. I spent a LOT of time trying to make those patches look perfect and thought I had succeeded. Then the sexy glossy paint went on and this showed up.
And this is what I'm working on tonight to fix it. (IMG:style_emoticons/default/biggrin.gif)
I did a little better on the other side, but boy did I waste a lot of time on it.
Keep up the great work (IMG:style_emoticons/default/smilie_pokal.gif)
TravisNeff
post Nov 20 2018, 08:51 PM
Post #242
Well it is not the worst and it sure as hell can be a lot better. Lets see if I can make a patch piece first before I commit to cutting bait.
This is just about the right width. Had to get ingenious on how to do this 4 bend so close together, I can only do 2 primary (center) bends on my cheap-o brake.
TravisNeff
post Nov 20 2018, 08:52 PM
Post #243
There are a lot of little things that only YOU would know about that no one else would spot. funny how it eats at ya.
TravisNeff
post Nov 20 2018, 09:57 PM
Post #244
Out it comes. The metal on the bottom (darkened metal) is paper thin. I will cut a little further down as I have some extra on my patch.
Test fit and it looks like a good start.
Larmo63
post Nov 20 2018, 11:35 PM
Post #245
I like my battle scars to show. Of course, I primed here and painted it black, but it shows.....
defianty
post Nov 21 2018, 03:05 AM
Post #246
QUOTE(TravisNeff @ Nov 21 2018, 03:57 AM) *
That looks a better job and similar to how I repaired mine. I too was limited to what my brake could do. Nicely done though and it's always good to revisit something if you think it's not quite right. The reward of getting it right is worth the hassle!
TravisNeff
post Nov 21 2018, 02:31 PM
Post #247
time to feed the OCD. I cut a little more, if the pic looks like it is paper thin towards the lower left - it is! I am down to better metal. I am contemplating patching the entire flat area, there is some weird built up tension. When I cut the piece(s) loose the back wall instantly did a pucker.
Fitting the new piece. I am no good about putting my tools away so a little improvisation with some allen wrenches was needed. I will fine tune the bends a little more too.
TravisNeff
post Nov 21 2018, 03:07 PM
Post #248
A view from the side you will see. Hmm. I am going to attempt to remake this and shoot for a sharper line in by bend.
TravisNeff
post Nov 21 2018, 05:26 PM
Post #249
Made another test piece to see if I can get the profile a little sharper.
worn
post Nov 21 2018, 06:24 PM
Post #250
QUOTE(TravisNeff @ Nov 21 2018, 04:26 PM) *
A bit too wide maybe? Depends on how you squint. But life is short. If you like, I bet we can get a signed affidavit absolving you of all guilt. Theses things bug the holy crp outa me. Not sure there’s a cure either.
TravisNeff
post Nov 21 2018, 07:17 PM
Post #251
That was just to test out if I could get the profile sharper. And yes, its off on the overall width
I ended up modifying the patch I previously made and got the edges a little more crisp. I am cleaning the hell out of the new and old metal as best I can. Wish me luck
bbrock
post Nov 21 2018, 07:35 PM
Post #252
Love the allen wrenches in the panel clamps (IMG:style_emoticons/default/beer.gif)
TravisNeff
post Nov 21 2018, 09:36 PM
Post #253
It's in. No butt weld would be complete without being able to play musical stringers once your done.
bbrock
post Nov 21 2018, 11:51 PM
Post #254
Well done!
TravisNeff
post Nov 24 2018, 03:56 PM
Post #255
More work on this. I ended up having to weld the backside. Ground down and dealt with shrinkage of the joint. There are a couple of pinholes still, but I am going to quit while I am ahead and move onto something else. I'll come back to this later. Pretty happy with the results so far.
sixnotfour
post Nov 24 2018, 06:40 PM
Post #256
well done...dead pedal?? (IMG:style_emoticons/default/slap.gif)
TravisNeff
post Nov 24 2018, 06:56 PM
Post #257
Yeah, yeah. I have so much OCD on the pedal that I am getting stagefright. Going to weld in the seat hinges next. I can then put in the driver seat and figure out the dead pedal.
TravisNeff
post Nov 24 2018, 10:19 PM
Post #258
seat hinge mount thingies in place.
sixnotfour
post Nov 24 2018, 10:20 PM
Post #259
TravisNeff
post Dec 1 2018, 05:40 PM
Post #260
Finishing up the oil cooler setup. I cut the opening a little bigger and used some of these nifty weld nuts I got from RD. I am going to have to re-glass the top flange of the cooler duct. Someone cut it a little short when they made it.
- Lo-Fi Version Time is now: 3rd July 2026 - 12:22 PM
