23 Pages V « < 16 17 18 19 20 > »
> Travis' 72 914-6 Conversion
914forme
post Jan 7 2019, 06:17 PM
Post #341
I like it, I would just counter bore two holes and just use machine screws to bolt it to you base.
TravisNeff
post Jan 8 2019, 07:51 PM
Post #342
Followed your advice, I spotfaced the holes with a leftover milling bit, dished it with a large bit and then the hole for the screw shank. I am going to try to find some nuts that are mild steel instead of stainless so I can weld it to the back. Once the pedal is in place i wont be able to get back there again.
I also decided on going with my original oil line cover, it looks like hell because I am trying to fix up some of the screw ups.
914forme
post Jan 8 2019, 08:05 PM
Post #343
rivet nuts would also work
TravisNeff
post Jan 14 2019, 06:40 PM
Post #344
Did some more work on the dead pedal. Added more to the attachment flange, drilled and belled a big huge hole in the side and filled in the top with some sheet metal.
914forme
post Jan 14 2019, 07:45 PM
Post #345
Bottom open I hope? That would be my suggestion just to keep it from trapping crap in cavity via the hole.
I do like it, just odd enough to make me (IMG:style_emoticons/default/biggrin.gif)
TravisNeff
post Jan 14 2019, 07:55 PM
Post #346
Yes bottom open, top closed.
bbrock
post Jan 14 2019, 08:09 PM
Post #347
Hmm... something's missing...
https://www.youtube.com/watch?v=M1dCAQfkqyA
TravisNeff
post Jan 20 2019, 01:20 PM
Post #348
Rebuilt the front of the passenger torque box, it was rotted through both layers of metal. I was able to save the outer flanged piece, that was the only part not rusted.
TravisNeff
post Jan 26 2019, 09:12 AM
Post #349
Time to revisit one of the first repairs I did. I have been hiding this ugly from all of you for a while - but here it is.
Well, when I put the trunk floor In I had to pull in the back panel in a good 3/4 of an inch along the center. While this will be covered by the bumper, I need to try and fix it a little better. I think I need to cut a slit in the back of the trunk floor and get the back panel flat again then stitch in metal along the cut.
I had to patch the back panel too as it was pitted through in a couple of spots. A long long time ago the rear panel and the passenger quarter were replaced with factory parts I think (red oxide primer on the backs on them). The panel has some crinkles in it too, time to remove some paint and figure out what's what.
bbrock
post Jan 26 2019, 09:41 AM
Post #350
QUOTE(TravisNeff @ Jan 26 2019, 08:12 AM) *
I have a couple of those spots hiding behind my rotisserie mounts too. (IMG:style_emoticons/default/popcorn[1].gif)
Tdskip
post Jan 26 2019, 10:35 AM
Post #351
Look at all that unused shelving, someone quick get that man two or three more projects!
TravisNeff
post Jan 26 2019, 12:44 PM
Post #352
Paint removed. Found some more rust and the backing plate didn't have any primer on it. I am thinking that the whole panel needs to come out. Something is not right with the inward bow where the trunk floor meets the back panel.
Plus I am not sure how to get to the drivers side damage and fix.
TravisNeff
post Jan 26 2019, 04:20 PM
Post #353
What an asspain!.I win..
TravisNeff
post Jan 26 2019, 06:25 PM
Post #354
I could only get so far with straightening this side panel. not much access for a dolly. I cheated and used a torch to heat it up before I could beat it sorta back into shape. There was a few spots of braze and sure enough it was for some holes. This corner piece is shot.
So after all that, I cut out the corner and will have to make a replacement piece. It will be a challenge because of the curve.
sixnotfour
post Jan 26 2019, 08:50 PM
Post #355
(IMG:style_emoticons/default/first.gif)
mb911
post Jan 27 2019, 09:02 AM
Post #356
That is one tough spot to fab a part for. I always have considered just buying the entire back piece from restoration design for my car.. Though mine worked our pretty nicely..
post Jan 27 2019, 09:49 AM
Post #357
914-6 GT in waiting
914sixer sent me a part from a car he's cutting up. Maybe give him a PM.
@914sixer
TravisNeff
post Jan 27 2019, 11:30 AM
Post #358
Kicking ass this morning, el fabricato
TravisNeff
post Jan 27 2019, 12:16 PM
Post #359
Couple of pinholes and I have to trim the side to fit, other than that I am VERY happy how this turned out.
bbrock
post Jan 27 2019, 04:12 PM
Post #360
Whoa! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif)
- Lo-Fi Version Time is now: 3rd July 2026 - 10:15 AM
