2 pair 911 - 3.5” Boge front struts for sale |
mepstein |
Jun 5 2018, 01:02 PM
914-6 GT in waiting Group: Members Posts: 19,274 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
2 pair 911 - 3.5” Boge front struts for sale The first pair I think is from an SC. They are in very good condition and inserts seem to be fine but are sold - as is.
The second pair is probably from a Carrera since it has the bracket for the brake sensor. You don’t need the sensor to use these struts. Inserts are functional but - as is. There should be no functional difference between either pair. I don’t know if the Carrera inserts are valves for a slightly heavier car. Both pairs will accept Billstein strut inserts (made for Boge struts) , the inserts usually come with both types of top caps, internal and external. Both pairs will only accept calipers with 3.5” spacing or need adaptors to use other calipers like Boxster brakes. $450 + ship (usually around $50 xcountry) Email - mark@markepstein.net to purchase Attached image(s) |
flmont |
Jun 7 2018, 06:05 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
what does the 3.5" spacing have to do with the 5 lug conversion,is that for a specific type of rim and rotor ?? (IMG:style_emoticons/default/confused24.gif) Thanks Frank
mepstein |
Jun 7 2018, 06:19 PM
what does the 3.5" spacing have to do with the 5 lug conversion,is that for a specific type of rim and rotor ?? (IMG:style_emoticons/default/confused24.gif) Thanks Frank It determines which front brake caliper you can use. |
Lo-Fi Version | Time is now: 19th May 2024 - 02:07 AM |
