Sail panel bottom trim hole size? |
914xr75 |
Jun 9 2018, 10:30 AM
Member Group: Members Posts: 174 Joined: 24-March 18 From: Whittier, CA Member No.: 21,996 Region Association: Southern California |
76-914 |
Jun 9 2018, 11:23 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm trying to find out the size of the four holes that fit the bottom bright trim on the sail panel. If anyone can help me out with their calipers I'd appreciate it. My car does not have the appearance group but I really like the look of the vinyl. Thanks Not much to offer up to your question but...............if your using the new clips for Sierra Madre you will need to increase the OEM hole size 2 or 3 sizes. Otherwise you will ruin that small trim piece. Ask me how I know. (IMG:style_emoticons/default/mad.gif) |
914xr75 |
Jun 9 2018, 10:45 PM
Thanks for the info. I'm actually using original Porsche clips. I was trying to avoid buying multiple sizes of drill bits.
cn2800 |
Jun 10 2018, 12:52 PM
Member Group: Members Posts: 119 Joined: 11-August 14 From: Amarillo, Texas Member No.: 17,766 Region Association: None |
I measured all of mine with a digital micrometer, and got a range from 5.1 to 5.3 millimeters.
914xr75 |
Jun 15 2018, 11:21 PM
I just came back to my post to add the answer to this question and found out that someone came to my rescue. Thank you so much cn2800. Awesome. 5 mm is what I figured out. I'm sure if I put a caliper to my new holes they'd be the same range you have. Thanks again. Hopefully I can help you out one day with an answer.
Lo-Fi Version | Time is now: 29th April 2024 - 12:06 PM |
