New GB LED replacment Bulbs $99 a set, Option for H4 housings for those that need them |
Mikey914 |
Jun 10 2018, 01:19 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
We have another large shipment of LED bulbs that are inbound and are offering up another GB. They have went up a little, but these are literally night and day. We did a tech session on how to Install at WCR Sat morning an even during the daylight you can easily see the improvement. We have sold quite a few of these units and have found them to be the best on the market for the price point.
Matts did a nice comparison of his sealed beam units to these and it's pretty evident the improvement. I did easily see a vast improvement, and also noted they stayed just a bright while I was idling due to the lower load on the system. That in itself is a major selling point for me. So who's in? Attached image(s) |
Mikey914 |
Jun 10 2018, 01:20 PM
after
Attached image(s) |
Mikey914 |
Jun 10 2018, 01:22 PM
The difference is not as dramatic on high beams (unless you are looking at the current draw).
Attached image(s) |
Mikey914 |
After on High beam (LED) Note the focal points on the pavement. You can clearly see how they are more defined.
It may also be that with the fog lamps on the comparison looks a little less dramatic. Attached image(s) |
Mikey914 |
Jun 10 2018, 01:26 PM
Creamsicle New Zealand |
Jun 10 2018, 02:08 PM
Member Group: Members Posts: 83 Joined: 5-February 15 From: New Zealand Member No.: 18,403 Region Association: Australia and New Zealand |
Hi there do you have any units which will do for right hand drive country's? The beam will need to point slightly to the left for me. Cheers |
Mikey914 |
Jun 10 2018, 02:11 PM
We do not offer the housings you need, but I suspect you could obtain locally pretty easily. We are offering the LED bulbs that fit into the H4 housings. We do offer the option for the H4 housings in left hand drive.
wysri9 |
Jun 11 2018, 01:29 AM
Member Group: Members Posts: 199 Joined: 23-August 13 From: Aberdeen, Scotland Member No.: 16,291 Region Association: England |
We do not offer the housings you need, but I suspect you could obtain locally pretty easily. We are offering the LED bulbs that fit into the H4 housings. We do offer the option for the H4 housings in left hand drive. I'm in on the basis that these bulbs are a straight install in either LH or RH drive housings?? (IMG:style_emoticons/default/beerchug.gif) |
Mikey914 |
Jun 11 2018, 09:43 AM
That is correct. As long as you can locate an H4 housing. Let me know what you find locally, I'm interested.
Some discussion on Rennlist on the subject https://rennlist.com/forums/928-forum/59711...r-into-lhd.html |
Jonathan Livesay |
Jun 11 2018, 11:31 AM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
I'd like a set.
theer |
Jun 11 2018, 12:15 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
do these also fit the 944?
Mikey914 |
Jun 11 2018, 12:24 PM
Yes they do.
Jun 11 2018, 02:00 PM
Im in for a set please.
914_teener |
Jun 11 2018, 02:58 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
I.m definately in. Just got my rear trunk seal so on to the next one.
914sgofast2 |
Jun 11 2018, 03:03 PM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I will take a set too!
Mike D. |
Mikey914 |
Jun 12 2018, 09:15 AM
Excellent.
These are still about 10-14 days out so I will not wrap into the other group buys unless I get a PM to do so. This should be open until the 1st. |
Justinp71 |
Jun 30 2018, 04:26 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I would like a set, I already have h4 housings. Thanks. Let me know how to pay.
scallyk9 |
Jun 30 2018, 05:07 PM
Member Group: Members Posts: 318 Joined: 16-October 16 From: Port Orchard, WA, USA Member No.: 20,499 Region Association: Pacific Northwest |
Me too. One set please. I already have H4 housings.
914forme |
Jun 30 2018, 09:07 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
Add me to the list.
Have H4 Housing the ultimate Cibie Z Beam Lens, wonder how they will work in them. (IMG:style_emoticons/default/idea.gif) |
treemn |
Jun 30 2018, 10:34 PM
Member Group: Benefactors Posts: 50 Joined: 25-December 02 From: Klamath Falls,Oregon Member No.: 13 Region Association: None |
One set please.
Lo-Fi Version | Time is now: 26th April 2024 - 08:04 PM |
