Barely used MSD Digital AL6 + parts F/S, MSD Parts bundle For 4-6- or 8 |
forrestkhaag |
Jun 11 2018, 05:21 PM
I have for sale a slightly used and perfectly working MSD AL-6 Digital Ignition box, mounting package, and complete unopened wiring harness bundle for sale. This is the latest MSD offering and has the easy to adjust built-in RPM limiter / not the plug in limiter modules. It is brand shiny new in appearance and works flawlessly on my 3 liter 911 motor with stock recurved dizzy (offered separately).
The Digital 6A is a microprocessor controlled, capacitive discharge ignition that multi sparks up to 3,000 RPM providing easy starts, a clean, smooth idle and quick throttle response by optimizing your engines efficiency. Above 3,000 RPM, a single spark stays lit for up to 20⁰ of crankshaft rotation ensuring a complete burn of the air / fuel mixture in every cylinder. A sealed, locking connector keeps the minimal wiring of the 6A tidy for a clean installation in all applications. It can be run on 4, 6 and 8 cylinder engines with a 12 volt negative ground electrical system and can be triggered with breaker points, an electronic amplifier or magnetic pickups. Features: Easy Starts Smooth Idle Quick throttle response Built-in LED for system checks Full, capacitive discharge ignition power throughout the RPM range Compatible with 4, 6 or 8 - cylinder engines Tach output wire Sealed, locking connector for instructions see: http://documents.msdperformance.com/6201.pdf This package is offered for 150.00USD + shipping. Please PM if interested (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
jkb944t |
Jun 12 2018, 05:58 AM
Member Group: Members Posts: 464 Joined: 17-January 05 From: Canton, OH Member No.: 3,459 Region Association: None |
That is an excellent deal on a very good unit! I use this same unit on my 2.2L E engine and have been very happy with it.
Jeff B |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:25 AM |
